Since passing my class 2 back in july this year, I have worked for two companies, the second being agency work, and both have told me different ways of filling the centre fields out.
The first said to fill out Surname and initial for the driver name, the second has said surname and christian name.
Since this time I have been told that the police believe it is again surname and initial.
I could do with getting it right as I really do not fancy an astronomicle fine from the ministry. Any help will be gratefully recieved.
The legal requirement is surname then christian name. If you have a name which does not fit legably onto the centre field use the intial for christian name & then write full surname & christian name on reverse of chart.
Actually I’ve been considering this, and i think the only requirement is for the full name to be shown, regardless of which order. So in that case, christian name, surname or surname, christian name would both be fine. Not totally sure to be honest!
I read recently that any order was OK, as long as you had your Christian name and Surname in full, no initials. I have not been able to get that confirmed officialy though. So, to be certain of not being wrong, I still put in Surname first, followed by Christian name (in full).
There is no point taking a risk on something so petty, which could still cost you your licence, which you have just invested so much into getting. Better safe than sorry.
the way i was taught to do it was surname followed by christian name.intials will be a tchograph infringment but you are allowed to shorten your name if it will not fit in the box and put the full name on the back of your card.
i.e
whiting.jonathanok
whiting.jon(full name on the back of card)ok
Article 15 E.C 3821/85.
5. Each crew member shall enter the following infomation on his record sheet.
(a) on beginning to use his sheet- his surname & first name.
The law being black & white this means first name & surname is not in accordance with the law.
Drivers must enter
Surname
Firstname
Date of chart start
Place of chart start
Date of chart end
Place of chart end
Vehicle Registration
Start Odometer
End Odometer
