Sorry to be a pain, but I note others have mad the same comment, but no response yet from the moderator or operater.
I constantly seem to be getting no website when I click via my favourites ( all other websites are fine ) and or access is very hit and miss, sometimes it is there, other times it is not.
The only way when it is down is to go into Google and click in one of the Trucknet sub headings and cross the fingers.
Clearly the website has a gremlin, can it be sorted please ? just that the website is so much enjoyed, I miss my daily fix !
Ringrose:
hi ringrose,managed to get into this site this evening,not been able to get in since Friday!!..chris
Harry Gill apparently has the same problem logging on.
hi dave, it was close, the bloody compooter was nearly out the window!! …chris
trunkera1:
Harry Gill apparently has the same problem logging on.hi dave, it was close, the bloody compooter was nearly out the window!! …chris
Don’t be hasty Chris,it’s not the computer if others are having problems. It’s all Capello’s fault.
Hi I had same problems getting on today even went via Google search but no good!!!
I can get in using my phone but can’t using my computer!
There’ve been access problems from Finland too - related to my ISP’s DNS server I think, and last time I spoke to “Kyro” he was having problems too (maybe his ISP is Sonera too). It sounds from reading the posts above that the DNS problems could be more widespread? I googled the raw IP address and used the site via that for a bit, then found openDNS and used that instead of my ISP’s default DNS servers. That seems to have cured the problem permanently.
yep been having the same problems getting on too.
but last night when i shut my pc down i switched it of at the wall aswell & hey presto im back on
cheers
gaz
tetragaz:
yep been having the same problems getting on too.but last night when i shut my pc down i switched it of at the wall aswell & hey presto im back on
cheers
gaz
Is Rikki in South Africa watching the Football because getting into the site at the moment is b****y terrible!!! Bewick.
tetragaz:
cheers
gazIs Rikki in South Africa watching the Football because getting into the site at the moment is b****y terrible!!! Bewick.
there’s several threads about this in the Feedback forum ( and a global thread at the top of every forum )
it seems technical to me but as I understand it, it’s a error in the Internet providers system ( mainly Tiscali ) I had the problem too
hopefully it’'s sorted now !
If anyone has a problem in the future can you let us know via the feedback forum , the sooner we know the sooner we might be able to sort it out
It seems that the problem with sky has been rectified as I can now access using my computer.
The Highway Man:
It was /is a DNS related issue, As soon as i changed to Open DNS it loaded, but would not using Easynet’s dns servers (Sky/Ukonline
It was over a week that I couldn’t access the site. I didn’t change any settings so I can only assume that one of my ISP techies rectified the fault.
