erfguy:
There was a couple in a car killed on the A7 near Langholm when one shed the load on a bend and I think that bought an end to it in the UK. Some of the timber boys will remember better than me. Eddie,
Hi Eddie , was one of Elliot Hendersons lads that has the accident and killed an elderly couple as far as I can remember.
The forestry commission had been talking about banning cross loading for a while and this unfortunate incident brought it forward.
I personally look at comments on the good old days of cross loading and wonder if it was the same loads I carried ?
I hated cross loaded timber with a passion !
We ran a large amount of 2m chipwood to the mill at cowie , now Norboard but at that time Caberboard and then Nexfor.
2.2 m went to the paper mill at Workington and for a while we ran 2.2m to Shotton paper mill.
Shotton till that point had been 3m pulp in 3 bolsters ( 38 ton so 24 ton on 40 footers).
I can vaguely remember loadin 2.5m logs across the trailer but cant remember where we went with them ?.
It was a total pain in the backside to load.
To get the front on you either had to put the front of the unit well into the ditch and get alongside the loader.
The timber cranes we used at that time had only single extensions and had not got a great reach !
This ment you could not get enough of a load on the front if loading straight over the cab , so it was in the ditch or jack knife the unit right
across the road.
Once the front was on and “Chapped” in on both sides you had to turn , without upsetting the load and get the back put on.
Then it was like climbing Mt Everest to get your belts on ! 4 belts on top , hooked together to make 2 long belts , running front to back.
Without falling off you scrambled around and got them sorted and then back down , 4 ratchets to tighten them ,then stand back and look at the load.
You then looked for the hollows and strapped across the load , pulling the long belts down on the logs…looked the part but did no earthly use !
At the very end( before it was banned) we were made to tie the load then net it (brick nets ) trying to get the nets off at the mill was a total pain in the ■■■■ !.
So I for one was never so glad to see something stopped.
We now run 5 bolster trailers for 1.9 ,2m and 2.2 pulp.
