Hi Guys ‘n’ Gals
Its a long shot but does anyone got or know where I can get a wiring diagram for the indicator stalk of a DAF XF95■■
Secondly, has the indicator stalk got its own relay??
Thanks in advance
Lucy
Hi Guys ‘n’ Gals
Thanks in advance
Lucy
Whats the problem with it then?? as I think we had the last two stalks in the country last week??
Horn stuck on last week so replaced them, now they dont work at all. Everything else (light flash, indicators) works fine
have tried the fuse for the horn as it is on its own.
Quite often the Jericho type horns that are factory fitted to DAFs and Renaults fail in the open position (they have an a couple of ours anyway) so they are going all the time and now it might have died all together. Just check the feed to the horn is working properly and you are getting a good 24volts at the plug before you try anything else. John.
