WTD
Hi not sure if I’ve made a mistake on WTD. I’ve started my shift at 05:30 and at 08:39 had a rest of 5hrs 21 mins, when do I need to take my next break thanks. A colleague mentioned it should be 6 hrs from 11:39? Is that correct? Thanks in advance
Spera:
6 hours from when you ended the 5hrs 21 mins rest is the legal answer 100%
Spera:
Your colleague is wrong, you should have had a break of 15 minutes or more no less than 6 hours working time from the end of the last break or rest period.
I see ROG has beat me to it :slight_smile:
ROG:
Spera:
That’s excellent news thankyou
tachograph:
Spera:
As always tachograph thanks for your reply
Spera:
Where does 11:39 come from?
stu675:
Spera:
My guess is the split daily rest of 3 + 9
ROG:
stu675:
Spera:
That’s what my colleague was talking about the split daily rest, but I’ve had 13 hours rest at end of that shift. From what’s been said that wouldn’t have mattered
Spera:
ROG:
stu675:
Spera:
Even if you was having a split daily rest period it wouldn’t make any difference to when your break was required, for the 6 hour rule you always need to take a break of 15 minutes or more no later than 6 hours working time from the end of the last break or rest period.
Spera:
ROG:
stu675:
Spera:
[emoji23] what if you were still on rest at 17:39? Would you have to have a break from your rest and have a break, or a rest■■?
What if you finished your rest at 17:30, would you have to still take a 15 min break at 17:39? Some people (colleagues) don’t think [emoji1787]
