Pete the post:
That’s a bit harsh, you don’t need power to tug, low gear and a few revs and if it don’t split and the dog clip goes in then no probs More power equals more stress on the clutch and drive axleAs for trailer height couldn’t the ASSessor have not just guided you in the correct procedure
Jobsworths
The thing you have to do when you go for assessments is show the assessors what they want to see. Some are more pedantic than others who will cut you some slack as they understand drivers can be nervous in this situation. I would suggest to others going for an assessment to make sure you give a good tug which clearly demonstrates that the fifth wheels jaws are locked on the pin.
As for the trailer height issue, the lad was advised on that. As for future assessments perhaps Mr Martyn and others might consider making a check list to take with them. I don’t know how assessors would react to that. No doubt one or two of the more ■■■■ ones would conjure up some objection but I can’t see why it should be frowned upon. Commiserations Mr.Martyn but look on the bright side. You can still show your face on here!
