Hi all — having not driven artics for very long, and within that only limited coupling/uncoupling requirements I have come to learn how krappy the test/training prepared me for this, particularly dropping suspension requirements
Some q’s I have which I am hoping people can advise on (I have searched the site but couldn’t find exactly what I needed)
1.the other day it took ages to wind up/down legs, they were very very slow. I have come to learn there is a slow/high gear? I thought when you pull the handle out towards you that controls the height of the trailers i.e. making it higher or lower, and when the handle is fully in it will wind legs up and down. Is that correct? And is there then another gear to control how fast legs wind up and down?
2.Should I be dropping suspension fully down before uncoupling and then wind trailer legs down and pull away and raise tractor unit to normal level after driving off? Which in essence would mean when coupling up I drop tractor down to rock bottom before getting underneath and if trailer is too high lift tractor accordingly?
Any advice will be much appreciated from the experienced bunch. Thanks
