hi chaps. i seem to have a problem with my daf 55 lf. the brake lights seem to be stuck on now. drove 100 miles @ was fine. left it overnight in yard. the lads loaded it for me @ now the brake lights are stuck on. ive lubrcatied the switch but makes no difference. any ideas for me?
Well,if you’ve found the pedal switch then take the wires off it and see what it does then,then connect the wires together,if the lights work then it’s still the switch that’s buggered.
On a similar subject had a a few DafAids at the dealer I used to work for for similar fault ended up being something wedged under Pedal, stones/pen etc etc
Brake light relay locked open.
