Jonny17291:
I understand what ur saying but you said I had incurred a 4th redcuded rest Fri but how did I here as
"Mon - 15:30 - 06:15 = 14hr 45
Tue - 15:30 - 06:00 = 14hr 30
Wed 15:30 - 05:30 = 14hr
Thu 16:25 - 03:00 = 10hr 30
tachograph:
Edit: Unfortunately you had another reduced daily rest period on Friday which made 4, that’s where you went wrong.
But why have I have incurred it here as it’s the same as the situation where u said I could have started at 15:00 on Friday.
I explained in an earlier post that I had mistakenly assumed that it was a partial rewrite of your original opening post.
Sent from my mobile.
Oh apologies Tacho, so just want to double check.
Is 3 reduced rests not 4 as my manager thought it was, as I’ve already had my 3rd reduced rest wed into thu. However if I had work on Fri I would have to start at minimum 14:00 if I finished at 03:00 fri morning. Correct?
Jonny17291:
Yes that’s 3 reduced daily rest periods, and you’re correct that if you had done another shift on Friday you could not have started before 14:00.
Thanks a lot tach for being so patient with me xD
Can I just ask you one final question, on thu what is the very latest I can finish.
No split rests in the 15’s
Mon - 15:30 - 06:30 = 15hr
Tue - 15:30 - 06:30 = 15hr
Wed -15:30 - 06:30 = 15hr
Thu -15:30 -… = 03:30 or 04:30?
One of our drivers thinks it’s 03:30 but I always thought it was 04:30 so thought I’d check that.
Many thanks Tacho!
blue estate:
Jonny17291:
4:30
Yep as blue estate said 04:30 is the latest you can finish on Thursday, this means you can fit an 11 hour daily rest period into the 24 hour period.
When it’s clicked and its actually quite simple looking at it now.
While I’m on the subject I have another question for you as I asked are driver trainer at our depot and he said only have 3 reduced rests in a Tacho week.
However does it reset earlier for example
Mon tue wed 3 reduced rests and I have thu off so approx 36 hours can I then do another 3 reduced rests?
Jonny17291:
You can have 3 reduced daily rest periods between weekly rest periods. so if you had reduced daily rest periods on Monday Tuesday and Wednesday then had a reduced weekly rest period on Thursday you could have another 3 reduced daily rest periods before another weekly rest period.
