How do you level a tesco double decker fridge trailer? I’m at a bay and the staff don’t speak English but are making gestures to higher the trailer
Nearside rear of the trailer. Underneath you should find the air suspension lever. Push it in and turn it to the right. The trailer will lift up at the back. Left for down. When you leave pull the handle back out and it will reset itself.
Edit when you leave do not drive forward at all before you reset the suspension as the air bags may be supported on the floor. Ours are like that and you will do a lot of damage if you pull forward first.
Thank you so much! Found it where you said under a hatch
ItsJoe:
No problem mate.
If you’re new to them mate, Make sure u always pull the handle straight out before u leave. Dont forget to reset it
ItsJoe:
A great post.
Driver asks for help, gets it, and the jobs a good 'un!
Trucking at its best.!!!
