Better to have strapped it - than to get a picture of it all over the bed f the trailer due to some cloggie who took the ■■■■ and braked too hard - or pulled away to sharp lol
you can never over secure a load - you are the one thats taking it not the loader
if they are afraid of you damaging their load then make them strap it
cheers
Steve
Well I had a full pallet of cement in bags go over, which is unusual as they don’t normally move an inch, and yes the curtains did stop it. Bulging a lot but still inside.
I’d rather spend an extra hour strapping and securing the load than spend a lifetime asking myself why I didnt do it after the loads fell out and injured/killed someone.
If in doubt…get the straps out !
then surely if you had strapped your load, it wouldn’t have moved. then you wouldn’t have bulging curtains and run the risk of injury when you try and open them!
i’m not saying i’m a saint, but i have picked up my fair share of spilled pallets. there are few things more fiddly than trying to restack a load of pop-rivets in open top containers (all of which were different sizes and bound for vauxhall) or more messy than a collapsed pallet of tile adhesive! i now prefer to strap my loads than spend ages trying to restack them.
and if you think they won’t come through your curtains, you might like to speak to the poor driver who closed the m1 after the tinsley viaduct last week when his load ended up spread across all 3 lanes!
timmo:
I jumped in back and restacked it with curtains shut. Took no longer than it would have to open it up and strap it, i picked it up from docks.
I think strapping down in a curtainsider is generally a good idea. Personally I do think it’s pushing ones luck to trust curtains hold your load in case of load movement. I admit, curtains do hold pretty well if the load moves and load doesn’t get any momentum before hitting a curtain. We’ve all seen bulging curtains and most of us, I included have seen such things in trailers we’ve been pulling.
Problems arise when moving load makes even a tiny hole into the curtain. This happens when load gets momentum before hitting the curtain (like huge paper reels) or has sharp edges (like steel sheets). After this, that part of the curtain doesn’t holdthe loads momentum and hole gets bigger in an instant. Then load continues it’s way through the curtain while your lorry travels somewhere else.
I use this as my own rule of thumb: If load is light and is loaded from curtain to curtain, it likely stays inside the curtains. If load is heavy and/or in middle of the trailer it likely goes through the curtains if it moves. Despite of this I’ve strapped load down as our local VOSA equivalent is happy even if you’re overweight but it’s strapped down. On the other hand, if your GVW is within legal limits but load is not strapped in curtainsider they give you fine.
Couple of months back in CZ, one driver loaded empty gas bottles onto his dropside 7.5t. No straps or nets. As he put it, “it was full load, very tight fit, side higher than the bottles, so the bottles had nowhere to go; done that many times liek that, no probs”.
This time he misjudged the speed of an approaching tipper when he was joining main road, crash boom bang, 7.5t spinning round, gas bottles flying around, pedestrains flying to safety.
mickfly:
I never strap down my load on the d/d curtain sider, and although it sometimes moves it has never escaped.
I never did either, but then I had a few truck engine and gear boxes on occasionally and if one of thems going to go, no amount of strapping will stop it…
mickfly:
I never did either, but then I had a few truck engine and gear boxes on occasionally and if one of thems going to go, no amount of strapping will stop it… :shock:
