stevieboy308:
Go carryfast, please try to convince me that having a kip whilst waiting to be loaded should be recorded as other work and it’s wrong to record that time as break.
I don’t understand what you’re struggling with as regard the no limit on duty
As I said it all gets a lot easier to understand when you look at the maximum 11 hour daily duty limit as being a minimum daily ( adequate ) rest limit by default.In just the same way that the 9 hour minimum daily rest limit is a maximum daily duty limit by default.Are you suggesting that 9 hours spent waiting for a call to leave the bay would count as daily rest and you can then start a new shift.Especially assuming that VOSA decide to ask you to prove that the 9 hours in question didn’t involve anything which could be termed as ‘duty’ or ‘standby’/ ‘poa’.
As for no duty limit see above.No that doesn’t mean spending 12,let alone 21,hours waiting for a delayed load on a loading dock,or for that matter doing other work,and then driving 3 hours to get back to base.
While as I said driving while tired is an offence which trumps all hours regs.In which case the ‘adequate’ rest provision contained in domestic regs is better when it comes to saying no than the stated unrealistically low 9 hours minimum daily rest contained in the EU regs.
I’d argue that it’s easier to understand when people stop making stuff up.
You’ve just invented a minimum daily rest into domestic regs, there isn’t one. you will keep struggling like you are until you accept this.
The 11 duty is driving + other work, again until you accept this you will only remain confused on the matter.
The difference between a 9 hour min rest effectively giving a max of 15 on eu is the 9 hours is 9 hours, start the 9 hours at midnight, at 0900 the 9 hours is up. The 11 max duty, can spread more than the 11 hours (because any time spent on break stops the 11 hour clock) and there’s no limit on the spread, so long as you have adequate rest.
If you’re talking about 9 off on a bay for eu rules. Then if you’ve not been able to dispose of your time as you wish. Then it wouldn’t be a rest as I’m sure you know.
The no limit on duty is just that, if you don’t drive for more than 4 hours each day of the week then that week each day doesn’t have a limit on duty. That doesn’t mean you can drive tired obviously, you could drive one hour, spend, say 12 hours digging a ditch, then drive one hour back, no breaks needed
