Reversing only comes with practice and it varies between people how quickly they master it, i was lucky because i’d driven large vans and 7.5 tonners for several years before going for me artic ticket, also was into banger racing so did many miles towing before getting a lorry that bent, still was big shock just how long an artic is when i got one mind.
It’s not as easy nowadays, yes you have power steering and vastly better mirrors (especially for keeping an eye of the nearside bumper/step/tank area) but you are saddled generally with automated clutch transmissions of varying levels of (in)competence, these will never be as good as a manual clutch or a proper torque converted clutch as fitted to Terberg Tugmasters and the like for infinitely controllable transmission take up needed for precise maneuvering, Volvo and Scania are streets ahead of arsetronic with its on/off switch clutch engagement, however others say they are now improved, but at the end of the day the automated clutch is always going to be a balancing act comparable with one person operating the throttle and someone else engaging the clutch.
For what its worth i never use the hill hold function either, i’ve known people to rely too much on the thing leading to all sorts of things happening including a runaway, to my thinking only one thing is on control pof that vehicle and thats the bod behind the wheel.
Also something else thats made life far more difficult now, when i started almost all tractor unit were day cabs, with windows all round, these made blind side reverses a doddle, indeed in a good day cab tractor is often easier to blind it in that go in on your own side.
As i always say to new drivers that i speak to who struggle to take advantage of any chances to practice and do it every day at least once or twice, if you are going up the motorway pop into the service area or decent lorry park, select a reverse in where you can’t possibly hit anything if you balls it up and spend 5 minutes reversing in, all angles that is and find which method suits you, if you’re stopping for a break don’t go in the easy drive in/out bays, reverse into one that needs a bit of care.
These are ideal places to practice your blind siders if you select a marked bay where even if you ■■■■■■■■ it right up you can’t do any damage.
Much better to perfect your reverses like this, than when you get to some bloody tight delivery point and have the mother of all awkward spots between two shiny lorries on a blind sider.
Always always get out and have a poke nose, i’d rather (and do sometimes) get out half a dozen times than hit something, nothing clever in being one shunt johnnie who does £20ks worth of damage in his haste to show his hexpertise.
Oh and if you see any blokes near other lorries laughing at you whilst you practice be assured they aint lorry drivers and never will be so long as they have a hole in their arse, any proper lorry driver will give a a metaphorical nod of approval for using you brain.
I still select an offset blind side by choice when i stop for a break in the services, doesn’t matter how long you’ve been doing the job you never know it all and you never stop learning and you have to keep practicing, still shocks me just how bloody big the lorry is when i get back in after a couple weeks off…
