andrew.s:
carryfast,ive really really tried to digest your answer to newmercmans question above,and i still cant get it…
so can you expain in simple English what difference it makes whether you float gears or double declutch?
and yes i have got plenty of experience of mr fullers wonderful 13 speed (about five years worth in total in two MAN F90 eight wheelers) ,my favourite gearbox ever,and yes i can do clutchless changes all day …
answer the bloody question without sounding like you just swallowed an eaton fuller instruction manual ffs.
Let’s get this right nmm made a sarcastic comment regarding the superiority of I shift over a manual along the lines that even the best super trucker will still get shifts wrong in the form of mismatched/missed shifts.By previous comments he’s clearly referring to floated shifts in that regard.
I’ve explained why floating gears makes a difference in that regard as confirmed by nmm’s comments IE without seperating the transmission from the engine when shifting into neutral and into the next gear the matching and timing has to be ‘perfect’.Arguably too perfect especially if it needs to be done fast.Which is why the instruction manual says use the bleedin clutch don’t float gears.
It’s only on ‘that’ basis that any arguable superiority of I shift over manual,at least regards the consistency of shift quality,needs to be viewed.
Sorry if that doesn’t fit the auto fan boy script but don’t shoot the messenger.
Again, what’s the difference between using the clutch or not? The meshing of the cogs takes place behind the clutch and half of them will be spinning at the same speed regardless of whether you use the clutch or not, the ones that will be slowed or speeded up during clutch disengagement will still need to match the speed of the others to mesh accurately, so it’s what you do with your right boot that’s important, not your left boot.
Making the perfect shift is all down to timing, regardless of how many appendages you use to do it and that is where ishift is superior, it has perfect timing and gives almost seamless changes, no way could you replicate a fast upshift without ripping it out of one gear and into the next and even then I doubt you could shift as fast and changing down, no chance.
As an example, coming over the Rockies this past week I have to approach the top of a hill ready to maintain control, first I have to downshift and engage the engine brake and once I start descending I have to change up or down and increase or decrease the engine brake performance to maintain a safe speed down the road, with ishift I just push the button on the end of the engine brake stalk to engage downhill cruise and it does it all for me, literally all of it, I set a speed and it goes down at that speed, obviously I need to be at the right speed on the approach and set a realistic speed for it to hold, but it’s a one touch and forget procedure and a safer way to descend a hill in a loaded lorry.
I did throw a little sarcasm into my earlier response, but in all seriousness, I have driven lorries with constant mesh gearboxes for half of my 30yrs of driving lorries, from 6spd boxes in Leyland Clydesdales, 6spd David Browns in Seddon Atkis, that awful 12spd ZF in Dafs and Mercs, twin splitters in ERF/Foden/Ford/Leyland/SA/IVECO/Hino, 9/10/13/18spd Fullers in Berliet/Dafs/ERF/Ford/MAN/KW/Peterbilt/Volvo. So I’m quite good at making them change gear without any fuss.
And I reckon ishift is the better gearbox by far.
Sent from my SM-T805W using Tapatalk
