Rjan:
Rjan:
And if you do feel that you’re about to enter a curve at too high a speed (or you’re about to hit adverse camber or mount a kerb), the best pre-primed reaction would be to go for the footbrake immediately, and if possible ease any turn that you have to make.On the brake, you could well be stopped dead (or at least back well within a comfortable margin) before you even have to make the fatal turn or before the trailer wheels have even hit the uneven surface, and any loss of forward speed will immediately reduce any lateral forces sustained.
As for those who talk of flooring their way out of a rollover, that seems to me like the ravings of a lunatic!
You can brake your way out of trouble so long as it’s all still in a straight line on the approach.But don’t try to do it after you’ve turned in because all the previous forward G forces then get transferred into lateral ones.
Obviously the earlier you catch things the better, and a hard brake application even just milliseconds before a turn, is far better than any fumbling you can manage with the steering once you’re turning.
Also bear in mind, the lateral forces are a product of the forward momentum and the degree of steering input (the vehicle doesn’t move crabwise). Even braking whilst turning, will immediately reduce lateral forces.
As for using power to over come roll it only works if it’s got enough power and it helps if it’s a rear engined rigid but definitely don’t try it with an artic. That thing will,or at least should,also have a full load of water on board.
A rear-engined rigid? Like a passenger bus?
With most automatic transmissions, once the wheels were up you’d be on your side before the gearbox had found the right gear for maximum power.
I’d stick by the principle that the answer to any perceived rollover risk is to brake as hard as necessary at the earliest opportunity. Whatever else you do, your right foot should be on the footbrake.
As I said braking from high speed in the middle of the bend certainly will usually result in a lateral off either in the form of under steer,over steer,or even both ends at once or with a high c of g and/or one of those weird artic things more likely to trip itself up and throw itself over on its side unless you can take off enough lock to straighten it up which is more or less the correct action described by Juddian.
As for the vid as I said ‘enough’ power and the right weight distribution to create mild over steer over roll.While a ‘bus’ might just about manage the weight distribution side but just doesn’t fit the definition of enough power unless you can put a 500 hp + motor in it.While notice the driver rightly applied power in the bend he didn’t dare brake.On that note you won’t make a fire truck test driver.
