Martin Bullock in his Volvo eight legger,seen on the A4111 exiting Eardisley going towards Hereford.
Local stone merchant Alpha Haulage Volvo artic,seen in the Strinds Quarry.
One of the static plant fitters,seen on the cherry picker at the Strinds.
Another of Ivor Duggan’s coming down from the lime bins,at the Strinds Quarry.
Mark Jones with his smart Scania coming down from the top level,at the Strinds with a load.
Another local operator,seen in the Strinds Quarry,coming down from the Dolyhir Quarry to weigh.
Clive Williams,son of John in their Scania,seen on the A44 near the Welsh Border.
Another one of C W Griffiths Volvo’s,seen at the Strinds Quarry.
FO9009 driven by Roddy Griffiths for C W Griffiths & Sons.
One of Bayliss brothers artics co ming down through the Srinds Quarry.
Hi Dave I,ve see most of the local tipper operators use Bulkrite bodies , which I think are made locally to you. Do you Know why ? are they light, well maid or cheap. I like the look of them and I,m not over happy with PPG bodies that i’ve used the last couple of times. There are couple of hauliers that I know have got them through second hand purchases with a mixed response.
Big Bear:
Hi Big Bear,
Bulkrite are based at Dorrington near Shrewsbury,they are good bodies, as you have noticed most of the operators this way have got them.Some of the hauliers wouldn’t have them unless they were good and reasonably priced. I can sound a couple of them out for feedback if it’s any help.Some of these have had PPG and others in the past.
Big Bear:
Hi Dave I,ve see most of the local tipper operators use Bulkrite bodies , which I think are made locally to you. Do you Know why ? are they light, well maid or cheap. I like the look of them and I,m not over happy with PPG bodies that i’ve used the last couple of times. There are couple of hauliers that I know have got them through second hand purchases with a mixed response.Hi Big Bear,
Thanks Dave, the PPG is a good body but when you get a problem you get a stoney silence from the factory.
We,ve tried them all over the years, recently Wilcox have become popular again in our area but the last one we had should have been called Wilcracks.
Big Bear:
Big Bear:
Cheers Dave.Thanks Dave, the PPG is a good body but when you get a problem you get a stoney silence from the factory.
Hi Big Bear,
Just had a word with one of the main operators out of these quarries about Bulkrite. He says that they are a little dearer,but the back crossmember is much stronger than some of the others you mention,you don’t get so much cracking etc,and he’s very pleased with themm. They don’t just make bodies they repair them alter them,extend them for whatever purpose. You also speak to the Boss there,not a salesman.They are in the process of setting up a website,at the moment,it only has contact detalis. I will PM the details.
C W Griffiths Volvo FO9009 seen in their yard.
John Williams Foden 4000 series parked outside his workshop.
John Williams first new Foden artic,this one hauled most of it’s time from Gore Quarry to Tilcon’s Pinvin plant near Pershore,Worcester.
John Williams artic,driven by son Clive,seen at thr Gore in the 90’s.
John Williams last Foden on Tilcon,first one as an owner driver.
