Warming up an engine
Buckstones:
Bking:
Get the engine under load to warm the cylinders.Otherwise the coolant keeps the cylinder walls cold and atomised fuel can get past the piston rings diluting the engine oil.Also liquid fuel acts as an abrasive which polishes the bores and rings reducing compression.
Somewhat confusing comment above:
I thought high pressure fuel pumps rely on the lubricating properties of diesel fuel (so fail when cars are mis-fuelled with petrol).
No diesel is a ‘relatively’ better lubricant than petrol bearing in mind that’s all the pump has to work with unlike the engine.While the engine needs oil not diesel to seperate the rings from the bores.In which case he’s right that diesel will wash/dilute/damage engine oil.But he’s wrong about an idling engine not warming up the cylinders and needing load especially in the case of the stats being closed.While an engine under load is obviously under much more fuelling than an idling engine.
So Biking’s suggestion creates the worst of all worlds situation of the cylinders still needing to get warm just the same to create the best combustion of the fuel and for the oil to reach a reasonable temperature.But he’s pushing in loads more fuel by subjecting the engine to load while it’s are doing it.As opposed to idling it at least until the thermostat starts to open ( around 75-80 degrees ).
newmercman:
I used the price I paid in July this year, so the numbers I used are relevant today. Yes the lorry is a rarity, it would appeal to probably one buyer in a hundred, but I’ll only need one buyer if I sell it.
Sent from my SM-G930W8 using Tapatalk
Agreed, but that logic doesn’t work for the masses of large haulers, who need to sell thousands of vehicles a year.
If they tried to keep everything going for 10 years instead of 3, those vehicles (when dumped onto the market) would have a much reduced residual than they have when very few owners are keeping vehicles going so long.
Any large volume seller in a marketplace has to factor in that their behaviour may change prices in a way that a small volune seller doesn’t usually need to worry about (the small seller can just take the market as they find it, and perhaps exploit the small gaps created by the policies of the larger sellers, gaps that would disappear if the small sellers tried to scale up the exploit, or if a mass of small sellers all acted the same way due to a common culture or shared perceptions of what is economically sensible).
Buckstones:
Bking:
How is it that the same fuel manages to become an abrasive in cylinders? Also, polished rings and cylinder walls should improve compression shouldn’t they? That’s how it works in air-rifles, hydraulic cylinders etc isn’t it?
I suspect liquid fuel does not become “abrasive”, it just dilutes or washes the cylinder walls of lubricating oil (and diesel is far too thin to be an adequate lubricant itself between the piston and block), so what you end up with is unlubricated parts.
Diesel is a spirit, so it cleans the film of oil off the metal parts, metal to metal means wear. Simple as that. Now this is just guess work, but the scoring on piston liners is there to give the oil something to grab on to, or somewhere to go when the rings slide past? Polished bores are a bad thing and it’s the only part I can think of that isn’t polished.
There is one exception to this that I know of, a company in America micro polishes the components of an engine, including the liners, tgey then give it a coating of some kind and it was supposed to reduce mechanical resistance to the point that it reduced fuel consumption, they also did wheel bearings, gearboxes and differentials, basically any moving parts. It came from NASCAR and was supposed to be the best thing since sliced bread. The company is called Micro Blue if anyone wants to delve deeper into the subject, Google will point you in the right direction.
newmercman:
Petrol is a spirit.But diesel is an oil with a certain amount of lubrication abilities at least regarding fuel pumps.Which is why diesel engines were known as oil engines in the early days.While the issue of the loss of diesel lubrication qualities reputedly has more to do with modern refining methods.
petrolplaza.com/knowledge/1982
Spot on concerning bore surfaces.They need a micro rough finish to retain the oil film on them.Which is why they are honed finished not polished.Modern honing methods having been perfected in that regard to provide the required troughs to hold the oil.While flattening the peaks to stop the old type of ring to bore interference they caused that required strict bedding in procedures.
coxengineering.sharepoint.com/P … azing.aspx
None of which helps Biking’s case that subjecting a cold engine to load during the warming process is supposedly better than letting it idle to warm up. :wink:
Rjan:
The bores require oil to lubricate them and diesel is detrimental to engine oil.While fuel pumps don’t generally have the luxury of engine oil lubrication they have to rely on the limited lubrication abilities of the diesel fuel.So Biking was correct in that regard.But driving a truck from a motorway services with a cold engine won’t help the situation of all the issues which apply within the engine during the warming up process,with the addition of load to the equation just magnifying not reducing all the downsides in that regard.
Mercedes recommend (providing the air pressure is sufficient) starting up and immediately moving off and reaching cruising speed as soon as possible, so pardon me if I take a boffins recommendation over that of some bloke from interwebland.
My company also want as little idling as possible and as it’s their train set that they pay me to play with please forgive me if I do it their way.
As an aside when I raced motorsickles I wouldn’t dream of racing on a cold engine, I’d probably start it up at least 3 or 4 times prior to going on track, each time letting the temperature climb a little higher before switching off and allowing the heat to soak through the machine.
Rjan:
They’ll also possibly have collapsed residuals when even the new start/owner driver/small haulage sub contract type of operation loses confidence in the used market at any age of vehicle and decides that out of warranty ex fleet heap that they know has been ‘thrashed’ from cold to save a few bob’s worth of diesel,is too much of a financial time bomb to take on.Unless it’s at a give away price which allows for a preventative major component replacement programme before putting it to work.
IE the used buyer is generally looking for a well treated motor that provides a good chance of the least possible financial risk for the most possible reliable mileage left in it.Whether it’s 3 years old or 10 years old.Assuming all trust among most potential buyers in finding that has disappeared then any fuel savings will be more than wiped out by poor residuals.Although there may always be a few naive mugs but doubtful enough.
On that note you can bet that if I was buying a used truck from someone who I know thinks that it’s better to ‘thrash’ a cold motor,to save a few bob in idling fuel costs,then they’d better be ready to be hit with a bid which allows me to put a factory exchange engine in it,not to mention loss of earnings while it’s off the road,before I even start. :bulb:
the maoster:
No one is arguing about what they are saying.The issue is the reasoning for it.With the thrash it from cold school of thought seeming to be partly based on Biking’s reasoning for one example.So the cylinder bores are just as cold the oil is not at its best operating temperature but now we’ve added load and the extra fuelling associated with it to the equation.How is that supposedly better than the no load idle situation and the obviously minimal idle fuelling rate ?.
Bking:
Great idea we want to minimise the fuel input while it’s warming up so let’s put the engine under load.Have you thought that idea through bearing in mind how a fuel map works. :open_mouth: :laughing: While if it takes load to warm up the cylinders why do we need bleedin great big fans to keep an idling engine cool while it’s stationary.Let alone when the thermostats are closed with no circulation at all to the radiator/oil cooler. :unamused:
What the hell you on about the oil cooler water flow is not controlled by the thermostat its bolted to the bloody engine block next to the oil filter.And the stat is there to keep the coolant at an optimum 85 degrees.The water in the rad is being cooled by the “bleedin great fan” to keep the system in equilibrium.Eg heat produced by combustion can be “radiated” from the coolant to keep the cycle going.Most of the time the"bleedin great fan" is free wheeling as air passing through the intercooler and radiator due to forward motion is more than enough to get rid of excess heat.
Buckstones:
Bking:
The diesel washes the oil off the cylinder walls so it acts as an abrasive and have you ever heard of a cylinder hone?
Its also called a glaze buster.That might give you a clue.
Bking:
Bking:
Firstly the oil cooler usually also has it’s own thermostat which closes off the oil flow through it until the oil is warm.
As for the fan yes it’s there to maintain cooling while the vehicle is stationary with no air flow and obviously at idle unless you’re saying that a stationary truck means the engine is under load.So why does it supposedly need load to warm the engine up ?.When we already know that an idling engine produces more than enough heat to the point of needing the fan to maintain cooling when the thermostat has opened if the vehicle doesn’t move.So let’s get this right the thermostat is closed,the engine is warming up at idle,why would we then want to add load to the engine before the thermostat has started to open ?.Bearing in mind that load obviously means more fuel going into the still cold warming engine washing the oil off the cylinder walls,not less.
If you got a truck that overheats on tickover you got one sick engine.
Bking:
Bking:
Thermostats in an oil cooler ?
You any idea what your talking about?
The oil cooler matrix is sitting inside the engine block connected to the oil filter housing.The reason its next to the oil filter is that,apart from when its in the sump,its where the oil spends the most time on its circuit so it gets longer to lose heat to the coolant.How the hell would you operate an oil cooler with stats in?The idea is to cool the oil not warm the bloody coolant.And if you think coolant runs hotter than the oil…
Well what is there to say.
Bking:
Buckstones:
I think on the proper analysis the washing off of lubricating oil leads to wear between unlubricated parts - it’s not the diesel itself that becomes abrasive, it’s the unlubricated parts which are abrasive.
Also the reason why hydraulic rams are polished while piston bores are honed is because each approach solves a different problem.
With hydraulic rams, it’s important that the hydraulic oil is retained under huge pressure (not present in an engine to the same degree), excess oiling of the exposed part of the ram would lead to soiling and retention of abrasives from the open air, the lateral forces are more modest, and the number of reciprocations far lower. I think rubber is the normal choice for hydraulic seals - this has good sealing capability, but a relatively short lifetime against the number of reciprocations of the ram, and would wear even more rapidly against an unpolished surface (without the honed surface adding any extra useful lubrication). The oil retained on the exposed side of the hydraulic seal is sufficient to re-lubricate the exposed side of the ram as it returns home through the seal (and cleaning and reoiling the exposed side of the seal manually from time to time, is a feasible servicing task, although worn seals would allow a certain amount of seepage anyway due to the oil pressure behind them).
With engines, rubber is not an acceptable kind of seal in the first place, and modest passage of oil into the combustion chamber is not a problem (and air in the combustion chamber is pre-filtered).
The more important factor is the retention of combustion gases, which is not a static pressure but varies through the combustion cycle, but again modest leakage of gases across the seal is acceptable (much moreso than for a hydraulic piston, where leaked oil could not be captured without additional equipment, and would cause the piston to gradually move of its own accord, which is undesirable in that application, and where the ingress of air into the hydraulic side is completely unacceptable).
Given that piston rings are not as sacrificial as rubber and are capable of wearing the bore, and neither the seals nor the bores are expected to be serviced as frequently as seals on hydraulic rams are (relative to the number of reciprocations completed), and considering that the combustion chamber is a hostile environment that will consume oil residue on exposed surfaces, honing the bores so that they retain extra oil to help lubricate the rings is considered a desirable and acceptable compromise.
The rings don’t wear against the honed surface as quickly as rubber would, because they have a harder surface and are not sufficiently flexible to fill into the troughs in the way that rubber would.
Correspondingly, polishing the bores in an engine would tighten the seal and save oil, but would also lead to inadequate lubrication and therefore rampant wear of both rings and bore (which, if not serviced, would eventually cause the seal to degrade to a point far worse than that caused by honing), and the loss of lubrication also leads to the forfeit of the sealing effects of the oil itself, which when present frustrates the passage of high-pressure combustion gases across the seal and into the crankcase (similar to how a stuffing box on a boat uses thick grease and reinforcing fabric to prevent the ingress of seawater along the propellor shaft and into the boat).
This gets me thinking, nowadays mechanical engineering is seen as like baking a cake, but engines incorporate enormously complex physical processes. This is a prime example, where if you’d asked me what the role of oil was in an engine, I’d have said lubrication, without ever considering its (more minor) function as a gas seal - as well as cooling, cleaning, noise reduction, and probably other desirable side effects.
A truck engine at idle (about 5/600 rpm) will never produce enough heat to warm the 50 or 60 litres of coolant to anywhere near 85 degrees centigrade.It may heat up the coolant in the head to about this temperature but it will never warm the block galleries to any where near.Plus you have the flow to the cab heater matrix if the heating is on which is independent of the thermostats as it is fed direct from the cylinder head by water pump pressure which will circulate coolant around the block,heads and heater.Leave the vehicle at tickover turn the heater up full and turn on the blower.The heater matrix alone is more than enough to keep an idling engine cool and it wont even crack the stats to pass coolant round the rad.You will feel the air temperature from the heater drop in a couple of minutes because your taking more heat out than the engine at idle can put back into the coolant.
Rjan:
Which leaves the question how does putting the extra fuelling associated with load into the cold warming cylinder supposedly have a beneficial effect regarding diesel wash.As opposed to the lesser fuelling associated with idling when put into the same cold warming cylinder ?.Not to mention the far greater forces being applied to the compromised lubrication ability of the oil by applying load to the engine before it’s reached its optimum working temperature,including bearing surfaces and piston to bore thrust interface ?.This is all basic mechanical knowledge that our fathers taught us.IE don’t thrash a cold engine and ideally let it idle until the thermostat starts to open at which point the engine is near enough at its operating temperature for the radiator to do its job.Which means might as well get the vehicle moving. :bulb:
Anyone else get to the end of that? [emoji2]
Sent from my SM-J510FN using Tapatalk
P Stoff:
It’s what happens when I think out loud :laughing:
The battle of google. A memorial shall be erected to remember the fallen posters.
