what design issues with the FH do you want to see
I have often wondered why manufactures never bother to consult actual users when trying to improve on their products.
as an example…
make sure we can use the inspection light when hooking up a trailer, without having to have any lights on. (how many fuses have we replaced over the years!)
other basic ideas spring to mind…
how about a unit that has a fifth wheel locking bar on the nearside, (along with the trailer brake, catwalk steps)
and why don’t trailer manufactures make it so we can retrieve numbers plates from the nearside of the trailer instead of the rear?
Suzie/airlines have been around for a long time now, they get tangled and stretched, surely by now we could have one combined airline/electric connection, again on the nearside of the unit.
why do they insist on having the unit suspension control on the floor, the buttons need to be high where we can reach them whilst still reversing etc.
also why have the the inspection light switch high and out of reach. if you have just been told to drop your trailer, it wants to be low and able to be reached when standing outside.
and why-o-why do they position the inspection lamp so as soon as you stand there, you create a shadow?.. get it high and above !!!
why cant we have mirrors that rotate when dirty/wet, so we can spin them around and get a clean dry mirror on request.
99% of wagon drivers today are not allowed to carry passengers, so why insist on fitting a passenger seat, use this space to install something we really need…a porta potty/toilet.
we don’t need a rev counter in modern wagons, so fit a LARGE speedometer, one where we can actually see the speed at a glance, and in MILES per hour for the uk market.
make Bluetooth connection/radio for mobile phones standard in all wagons.
get all manufactures to agree on a position for the hazard warning lights switch, and all use the same.
WINTER…a return of windscreen washer bottles inside the cab, since you don’t seem able to heat the containers to prevent freezing!
and how about changing the direction of the wiper-blades, so they don’t throw water all over the side window and mirror, every time you use the washers.
if we are not allowed to exceed 56/60 mph, then install a limiter/retarder on all trucks, that holds you back to this speed when going down hill (much like the old FH had)
seat memory settings. for day/night driver changes.
radio settings for same!
and how about installing a bloooody robot, behind the wheel, you seem to be doing everything else for us!
