billybigrig:
If we are going to go longer, that is the trailer to do so, forget those bloody things of Denby and Stan Robinson.In the DFT consultation; I should like to see all the unstable double deckers made into flat trailers. In fact bring in a 4.2m height limit for anything above 32 tonne gross weight.
Aye lad. Bring back t’orses n carts too
Qualify “unstable double deckers” ■■? It’s all down to the loading and the driving.
That said the one thing you and I, I’m certain, agree on is why the lord we couldn’t reduce heights and vastly increase stability, lowering the center of gravity by smarter chassis construction.
Everytime this type of issue rocks up it’s the same old tosh used in defence. We have moved from 20 odd tons on 20 odd foot trailers through to 44 on 45 footers. This is really just a continuing evolution, get over it.
On an unrelated subject I’m off to buy shares in Lamp post, road sign and truck mirror companies
I am over it, but still travel around. I do see some good driving, but a ■■■■ site more bad driving, clipping kerbs, bullying and vehicle awareness deficit from many drivers.
I started out with 20 ton loads on 20’ trailers and a slack load of liquid sloshing about in a lift tank on a 20’ skelly was ■■■■■■■ frightening.
To qualify. I shall reword my rant. I said in this Consultation I should like to see all double deckers converted to flats. I also said all vehicles over 32 tonne gross should have a 4.2 limit. You maybe not be able to afford a second truck, but many could if the rates improved by not carrying two loads on one trailer. As it is there are too many lorries, too little good work.
You mentioned stability and centre of gravity. I agree, and without using little wheels, why can we not bring the overall height down through proven continental engineering practices?
And to qualify;
How do YOU quantify that? High centre of Gravity or Speed. I will give you both.
And as a little light relief ![]()
Surely it was the lorry that overturned, not the driver… unless he was drunk ![]()
