Although ■■■’s come in various consistencys from the sweetest solid to the nastiest ■■■■■■■ out of ones bottom praying for a lump, anyone new to tramping can avoid taking a dump in the cab (never on the bunk, this doesnt happen) by getting familar with their own ■■■-cycle.
For me I work on a sliding scale of 0-5
0= The moments after youve just had a clean drop, a perfect ■■■, one where the only purpose of using loo roll is to put a shine on ones sheriffs badge. Known as the ‘glory wipe’.
1= Feeling fine its been a few hours since nipping off a nugget and confidence is high that a ■■■ is not needed for the forseable. Possible to engage a sleep cycle with no fear of rest interuption from a call downstairs.
2= Very early stages of moving into the ‘■■■ window’. One feels theres is definately activity in the back passage but trying to evacuate is pointless and would not bear any brown fruit as theres very little backpressure. Tell tale signs include little harmless ■■■■■ that can be let off in the company of others with a very low risk of discovery. Trying to force a ■■■■ should be avoided.
3= This stage is also known as the ‘drop window’. If you where at home or worked in an office you could simply go to the toilet confident in the knowledge there was more than enough time to prepare the toilet for the imminent drop. This preparation can be anything from wiping the loo seat to prelaying some sheets of loo roll on the seat to avoid that cold shock.
Confidence is so high that one can even prestart the ■■■ before entering the loo.
Theres a few sub cycles to this ranging from more pungent botty whiffs to mild twinges in ones tummy area. This is the stage normal people go to the toilet.
4= Now at stage 4 things are getting tricky. One will be annoyed with themselves that a stage 3 ■■■ opportunity was missed as now a ■■■ is imminent. Ideally at this stage one will be near a toilet but as usual this stage is triggered by being no where near one. Its possible to jump straight from a stage 1 or 2 to a stage 4 if ones body is feeling uncooperative.
Tell tale signs are extremely smelly ■■■■■ that at first are quite pleasurable in the confines of ones cab but now carry a fear element, painfull stomach cramps are appearing in waves to signal the arrival each strengthening ■■■■. Going off route at this stage is essential to locate a toilet. An emergency ■■■ in or around the cab will also be crossing ones mind.
Real Jedi ■■■ masters can perform a re-chew and in the right conditions reduce a stage 4 to a stage 3 temporarily. However this is not without risk and requires skill and concentration. Around 10 minutes can be acheived before bringing on total ■■■■ collapse and stage 5.
5= This is the stage where no matter where you are or what your doing your arse should be hovering over a toilet seat. Sweating, stomache cramps, fear of ■■■■■■■ all accompany this phase where one is conciously clamping their cutting muscle shut for all its worth. Simple everday tasks become virtually impossible. Even walking becomes difficult.
All control is about to be lost as the tortoise is now at its most curious, its not uncommon to have a niblet in ones undercrackers now that escaped before the panic clench.
Theres no point trying to act natural as your facial expression and hunched over demeanor will give away the mess your now in.
Finding an available ■■■ recepticle is like winning the lottery now, preconceived notions of political correctness are out the window. You have to ■■■ and dont care where.
This stage although the worst is also the most rewarding so embrace it and in the safety of ones home practice bringing it on.
Just my thoughts and not diffinitive or cast in stone. Stages can be skipped, its not an exact science. In fact I once did a wee at stage 1 and surprised myself by also doing a ■■■ at the same time.
