Franglais:
shugg:
At the risk of upsetting some most of the problem is down to driver error , auto-boxes require a little more care from the driver , ie, a check of the illuminated gear indicator will tell you which gear you are in , most drivers will know if the particular gear is correct , if its not then simply use the manual override and engage the correct one for the conditions , I have had the same problem with the I/shift which I found on several occasions was not any better than the others .
I make 4 minutes and no reply . . . yet . . from Juddian.
After you mate.
And i humbly thank me learned friend for the opportunity.
My humble apologies for being lax, was watching the last Sleepy Hollow of the current series with my fair maiden, Ichabod is doing his gentlemanly best.
Its one thing when the autobox fails to proceed, they all do that now and again and always will because its impossible to program every single variation into the computer in charge of the box.
Itās entirely another when the combination of an unfit for purpose gearbox and an engine lacking in lo revved torque combine to stall the engine immediately after a failed start so admirably described in some of the posts above, this doesnāt tend to happen with Volvo (also used in Renualt) boxes because they are the exception to the rule and are fit for purpose, and their engines tend to have some stall rev torque stillā¦maybe the EU boffins can make sure thatās programmed out at Euro7 i have no doubt theyāll do their best⦠
I as some others on this forum drive the vehicle constantly in manual when loaded, and most of the time when empty, in MANās when empty in manual the box will default to 3rd as start gear should you come to anywhere near stationary (it usually starts in 5th in auto unless you come to rest uphill or are starting from scratch), so a combination of auto and manual override at junctions has to be used to make any sort of normal progress that a lorry driver who takes a pride in their work would find acceptable, again dropped into manual as soon as moving.
We are lucky in that at least we still have the Profi (manual) option on our Arsetronics, where some fleets have auto only and indeed on the euro 6 DAF i was unfortunate enough to drive a few weeks agoā¦DAF what have you doneā¦the bloody gearbox reverts to auto and bloody eco within 30 seconds and even if you lock it as best you can in M, soon as you use the retarder it triggers return to auto.
Its utter garbage, canāt believe its from the same maker of the last one i had, a CF 460 manual which was a cracking little motor, and i still see it now and again with its new owner or driver passing everything on the road.
Indeed something myself and one of my compatriots have been monitoring is clutch and other failures on the fleet MANās, interesting that the manually driven vehicle is not only better on fuel overall its the only one which hasnāt yet needed a clutch and is proving less troublesome by a fair margin, this vehicle also gets warmed up and cooled down and will till itās no longer mine no matter what the bloody suits say otherwise.
Why do we drivers, or most of us anyway, know that many of these auto gearbox designs (Volvo excepted) are rubbish and the only way to make them perform efficiently is to take over and drive them ourselves, yet the companies keep agreeing with the sales bod and accepting them, makes a mockery of them being called auto, try steep hill climbing with many makes at full load weights and youāll end up stalling the thing unless you drive it in manual.
