dozy:
Coffeeholic:
dozy:
I guess it’s not easy driving a left ■■■■■■ in this country ,but surely if you’re vision is impaired you would take extra care by stopping at the end of the layby and spend a second or two too try and and make sure your exit is as safe as possibleEh?
So you stop and then when you see a gap big enough you start a heavy vehicle moving from a dead stop and by the time you are out of the lay-by that gap is a hell of a lot smaller.
Or
You ‘trundle’ down the lay-by watching for a gap you can merge into and when you see one, especially as it is a fellow truck driver way down the road who will likely sympathise with your situation and assist you, at which point you increase speed in an already moving vehicle thus getting up to speed quicker as there is less resistance to break to get the thing moving and being less of a hazard while doing so.
Mmmmhhh, tough call. You really do live up to your name eh?
God help us ,we’ve now got drivers who won’t stop and join a carriage way safely because they find pulling away in a HEAVY lorry difficult ,who the zb issuedthem with licences
It’s got nothing to do with ‘pulling away’ being supposedly ‘difficult’.It’s about seeing a reasonable gap in the traffic ( when he could see it ) and then going for it.Because in this case the design of the lay by means that there is a point of no return where vision is compromised while there is also no way to maintain a decent entry merge speed because the designers have decided to forget all about putting in a proper lay by exit/acceleration lane/entry slip.In which case it is the combination of lack of vision and/or the speed differential which was the problem and in which case it is foreseeable that a similar type of problem could happen even in the case of a RHD truck.Simply because of the combination of traffic levels and speed differentials between an NSL dual carriageway and a truck moving away from a virtual standstill.In general the law won’t regard anyone who disregards all the above by making a crisis,let alone a collision,out of a foreseeable drama as blameless.
