recently got into a 7.5t Merc (800,000km) and the reversing lights weren’t working. I refused to drive it. A notice has now appeared on the notice board stating that as it is not a legal requirement and an MOT failure, the lorry is fit to use. I am aware that it is not a legal requirement, but I am not sure where I stand. We deliver to hospitals and are often reversing in public car parks and reception area which have a lot of people around.
Just stick your hazards on and reverse very slowly, people will see whats going on. If they don’t, they won’t have seen a reversing light either. If your regularly reversing in busy areas with pedestrians about, your boss should really kit the wagons out with reversing beepers.
I noticed yesterday one of our lads was reversing near me and the trailer had no reversing lights and couldn’t see any on the unit either, meant to ask him about it but forgot; you’ve just reminded me.
Found this, don’t know if it’s right though.
By law a reversing light is classed as an optional light and not an obligatory light, therefore there is no requirement to have one at all. However it goes on to state that if you do have an optional light fitted then it must comply with regulations which merely state,
Just tell your boss that his time would have been better spent arranging a fix rather than writing memos. If it was me I would want it fixed on elf an safety grounds + it shows a bad and lazy company image etc…
Try checkin the fuse then bulbs if non of these it ciuld be the switch, bad earth, frayed wire etc.
Also your pre start checks should mention this every time the vehicle is used.
No, the general rule with optional lamps etc is that if they are fitted they must comply with the regulations. No requirement for them to actually work.
I’d be interested in your thoughts.
Cheers.
Right
It is a legal requirement that every light,fitted on a Vehicle,has to work.
Tell em that
Roymondo:
Roymondo:
if it went for an MOT today ,the reverse lights in their present condition ,would not cause the vehicle to fail…Your best to have a word with your boss and explain why you need them to work…But at the end of the day,the decision is his …Unless you have a customer who stipulates that they must work before being allowed on their property
Christ Almighty, we didn’t even have hazard flashers not so long ago, and if you wanted otherwise unheard of reversing lights, you either took the Rubbolite lenses off or shone a torch.
norb:
+1 Have had two vehicles pass MOT with non working reversing lights, one car one van. (I did get them sorted)
The artic trailer I use doesn’t have reversing lights. I just stick the beeper on for a bit and keep in mind that folk don’t expect it to start moving backwards.
Would I get boss to get them fixed, and would I refuse to use it until it could be looked at are two different things.
