As an aside on tyres generally.
Boeing 747 Jumbo, 450 ton take off weight. Total of 18 wheels, so 25tons each tyre. Inflated to about 200psi (14bar) with nitrogen.
Spending hours at minus 40deg C, and very low pressure, then under full load heating briefly to 200deg C as it stops the 170mph aircraft! Remoulded up to 7 times.
aerosavvy.com/aircraft-wheels/
But back to truck tyres, and from the above, I am having to rethink my position on remoulds.
"Retread tires? On aircraft?!
An aircraft tire carcass/casing (tire without the tread) is constructed super-tough. A carcass that is eligible for retread is a desirable asset; it has demonstrated that it can stand up to the abuse of airline operations.
Retreading a tire is less expensive than buying a new one. Some tires can be retread as many as 16 times! Airlines often retread tires less than the manufacturer’s limit as an added measure of safety. Another benefit: retreads have more plies than new tires so they can handle more takeoffs & landings.
Don’t retreads fall apart?
Let’s talk about commercial truck retreads for a moment… Big chunks of disintegrated tires litter the sides of busy highways. Is it fair to blame retread tires for the debris?
NHTSA Truck Tire Study
The U.S. National Highway Traffic Safety Administration published a commercial vehicle tire debris study. Researchers analyzed hundreds of tire debris samples to figure out why the tires failed. The results show that retread and Original Equipment (OE) tires fail at about the same rate.
The majority of truck tire failures (retread or OE) are not caused by problems with manufacturing. The number one cause of tire failure is “road hazard” — potholes, nails, car parts, and other hazards on the roadway.
The study lists the second highest cause of tire failure as “maintenance and operational issues” — overloaded trucks, improper tire inflation, and worn out tires. In other words, operators aren’t taking care of their tires."
I haven`t looked deeper into that, but probably will do later.
