Made a start on the haz boards tonight. The one on the right is how they come. However ours are a different set up. So once letraset numbers had been applied they were cut out into individual plates then attached to a black painted board. There’s a space on the board to attach a secondary placard. The numbers on the decal sheet are the emergency contact number that goes along the bottom of the board. The white strip will be painted black and fitted around the numbers as runners for the plates like on the full sized tanks
My latest build, Kew Dodge from the film ‘Hell Drivers’ complete with garage diorama. The entire model is built from scratch:
Always a lot of debate about the colour scheme of these wagons, however general consensus is green and black as they were loaned from W W Drinkwater. However to avoid argument, of course they were black and white in the film ![]()
Cheers
Ian
That is a cracker Ian,The garage is fantastic so real looking I tell you though the Dodge needs another 6"greedy board cause the rate them buggers went round corners some o that gravel is gonna come off. Seriously Ian another winner. Eddie.
Love the way the load stays put when the tipper is up Ian ![]()
Thanks Eddie, thats really kind of you mate ![]()
Hi Lemonmouth, I took the pciture then the load slipped into the garage
hehehe
finally got this finished,
scarren:
Cheers
Ian
wow, absolutly superb .
cheers
gaz
wirralpete:
another top job there wirralpete.
cheers
gaz
Hi Pete that is a cracker exactly like the real thing well done. Eddie.
Hi all another one just finished but still got to do the trailer, will post better pics when that’s finished ![]()
The real thing of course !! ![]()
Regards Jimski
Amazing work there JIMSKI
Nice work Jim
Your experience in Modelmaking is starting to show now
will look even better with the trailer ![]()
Trev
Blimey Jimski,
the detail on that model is amazing, it’s spot on mate.
Many thanks to you all !!
and Hi Trev nice to see you on hear will call you for nat soon !
Regards Jimski
Jimski, you missed the little marker lights off the bottom step tut tut tut ![]()
Another fantastic job, looking forward to seeing it with the trailer ![]()
newmercman:
Jimski, you missed the little marker lights off the bottom step tut tut tutAnother fantastic job, looking forward to seeing it with the trailer
What’s this a spot the differance competition ?
also the little peep mirror on top of passengers door and only one mirror offside !!! Anything else ■■..
R Jimmer
those 2 air tanks ■■ behind the diesel tank are higher up on the real thing
Comon guys, you’re picking flies there
It’s a very good realistic model and something to be really proud of, I wish I had the skill or patience to get one anywhere near that standard.
LeeJ:
Oh yeah… I’ll start another one !!
Jim, I think you’ll find that these ‘Rivet Counters’ couldn’t make a decent Model if they tried ![]()
