robroy:
stevieboy308:
i’m not leading you anywhere that isn’t obvious! do you think there needs to be regs? - yes, then wouldn’t you agree without enforcement there’s pretty much no point in having any regs? do i take it you disagree with the leeway they give? either way it’s a cop out to slag it off but not say where you’d draw the line
i read the perceived or true bit, it’s perceived because people like you saying it is!! even when some of them will know it’s not
the trouble with discretion, 2 men get stopped for the same thing by 2 different vosa men, one gets let off, the other gets a fine. they get talking a week later, well this isn’t fair, this isn’t right, one rule for one yada yada yada, everyone should get the same treatment. so they write out a graduated penalty book, listing loads of offenses and the punishment dependent on the severity, they even include how they’ll basically let you off with 15 minutes and a 1t or 5% on weight, they make it freely available so you can decide if the risk reward ratio stacks up for you! and what do people throw at them, well there should be discretion, they can’t win!
People like me’ saying it’s (zero tolerance) perceived by others, or people like me with the said perception which?
It’s proven that some perceive it by the way they get so stressed out over trivial infringements, read some past posts on here.
You can’t surely put me in that category, it,s only a couple of days ago that you accused me of appearing to not give a [zb]…you can’t have it both ways.
If you’re happy with the present system of things in terms of hours rules and all the details rules regs dos and do nots, (maybe complicated for a reason if there are any conspiracy theorists on) well fair enough, I would prefer an old style more simplified version of it all. I ain’t going to start devising a hypothetical set of rules and regs as an alternative to what we have now either, mainly because I can’t be arsed and am not interested enough to do so, if you think that,s a cop out well thats up to you.
If you want an example of how it baffles guys on different levels, read the last few posts and as I said at the start, , if you want examples of how other guys worry about trivial infringements ( yeh maybe within the leeway parameters you mention) go through the entire forum where you will find numerous examples.
In both cases a good argument for simplifying the present system, and maybe then there would be no need for my call for discretion, as everybody would be up to press, and less stressed out by no longer worrying that they may have made a balls up and PERCEIVE that the wrath of hell was about to come down on them.
yes, i didn’t word it very well! people, like you going on about zero tolerance, leads to a perception by others that there’s a zero tolerance.
you say you know it isn’t zero tolerance, you say you don’t agree with is this zero tolerance policy, either perceived or true, that has some drivers [zb] ing themselves if they happen to inadvertantly go over their driving time for all of 2 minutes. so why not say, dude, there isn’t a zero tolerance policy? who’s fault is the zero tolerance myth? - drivers spouting ■■■■■■■■, i thought you don’t suffer fools? tell them!
again maybe i didn’t word it very well, but i was never asking you to draw up a set of rules and regs, what i was meaning to ask, where would you draw the line if you didn’t agree with the 15 minutes grace? i’ve not said i think the regs are spot on and given the choice would prefer a much more simplified version
