the maoster:
Once again, yes or no, have you done van and man work in London? Simple question requiring a one word answer.
Run.
Run while you still can.
Pushing for a simple answer will eventually result in an answer that will cause you to want to rip your own arm off just to have something to hit the screen with!
Im still suffering from a couple of weeks ago when I wanted a simple yes or no from him. it took four hours of waffle before I got anything that even resembled an answer. And even that wasnt a straight yes or no. The answer was buried in a speech to rival the gettysburg address
the maoster:
What difference does fitting or not fitting whatever the strict definition of ‘man and van’ work happens to be make to the comments I’ve made regarding driving anything from a taxi cab to an artic on a regular basis for a living ‘in London’.
But to answer your question probably not depending on that definition.At least unless driving the works Transit around numerous places in the zb hole in the 1970’s counts.
boredwivdrivin:
The-Snowman:
Run.
pots and kettles
Not really. I always answer with a simple yes or no when asked a straight question. Unlike you who dodges answering by replying with a post peppered with insults and rambling that barely even resembles anything close to making sense.
The only reason I need to give long answers to you is because your a bit dim and cant seem to understand basic English so I have to give a long explanation.
