Laptop power supply
I have been looking at several threads on here about laptop power supplies. Using 12V, 24V, invertors, convertors etc.
What I am wondering is whether I am overlooking something as to why I can’t make a lead up with a resistor in to drop the 24v to the 20v required for my laptop (presumably most run at around that voltage). From what I remember from my electrical education its just a matter of calculating the correct resistance and having a suitably high current rated resistor.
Anyone have thoughts about this?
i was thinking the same.i was going to go to local electrical shop in town the lad who owns it is always messing about with things like that,im sure you would be able to get something to just plug into lighter socket to drop it down 6-8 volts.
would the resistor not get hot though? :blush: (i dont know much about resistors :open_mouth: )
Yes it would get hot if it was not capable of handling the power.
Also I suppose it would drain extra power from the battery.
It wouldn’t work as the voltage drop over a resistor is proportional to the current through it and so as the voltage presented to the laptop would vary as the current demand varied.
Paul
Yes thanks for that Repton.
I thought there must be a good reason why I shouldn’t try it. I guess it would be ok if the laptop drew a constant current, but as demand for power varies then as you say that would alter the voltage. By how much I doubt we would know, and it may even be within the tolerances of the laptops supply - but not worth risking.
Ohms Law prevails - back to the drawing board to find a design for a regulated power supply - probably cheaper and easier to buy one!
Get yourself one of these
Anderson Connector (Ensure you get correct size for unit connector)
Some of this
Wiggly Stuff
And a couple of these
Clips
With these on the other end to connect to the inverter
Connectors
And build yourself a cable with the Anderson connector in the middle of the wire so you can remove the crocodile clips and plug straight into the tail lift connector on the back of the unit (if it has one) or crocodile clip it to your battery and connect it to your inverter. Problem solved.
It is safe to run it through the door on your cab or through the side locker but be careful you do not pinch the wire on anything and cable tie it in strategic places.
Bobs your uncle and fannys your aunt laptop powered 24/7 and quickly removeable if need be
Thanks for that Giblsa, useful information - but its a laptop - not Blackpool Illuminations I want to run! :laughing: :laughing:
Smart Mart:
obviously these are just a rough guide, other amps are available!
i have this for when i am away (or used to be away as the case is now) and i run a tele, xbox360, kettle and laptop(charging phone and satnav) off it all at the same time. (not while i was driving :laughing: :laughing:) and it didnt sup the battery either. wagon started first time in the morning.
Giblsa:
Some of this
Wiggly Stuff
Clips
Connectors
similar set up to mine which works fine ,no problems.
I have one of these:
http://www.roadking.co.uk/products.asp?recnumber=201
And one of these:
http://www.roadking.co.uk/products.asp?recnumber=733
And it does my compaq dual core just fine.
allikat:
And one of these:
Ali,
i used to have one of those dropper and ciggie lighter charger thingys and if i ever watched a DVD on teh laptop it used to lose power (more drain than charge) so i went down the inverter route and , touch wood, so far have had no problems what so ever.
i suppose it depends what power your laptop draws for cetrtain activities on it.
Or you can shell out a bit more for a 12 - 24 - 28v power supply from
laptop-chargers.co.uk/dc.htm.
They also do them dedicated to your particular laptop brand/model for a bit more dosh. Go to their home page,and look up your lappy.
Simon:
link not working for me but i think its a similar peice of kit i use,got it off ebay for £25 and had no problem with it at all.my one came with different end plugs to suit most laptops and loads of fuse’s which you chose one which is correct voltage for the lappy (mines 18 volt)
http://www.laptop-chargers.co.uk/
Here is the home page for you Getz. :smiley:
thanks for that,mine is still working ok after 1 years service but will hang onto the site just incase
maplin.co.uk/Module.aspx?ModuleNo=44736
this is a 120 watt charger with 24 volt input at maplins or online £19.99 saving a tenner.
gezt:
http://www.maplin.co.uk/Module.aspx?ModuleNo=44736
Sorry you are wrong, it has a 12 volt input, and up to 24 volt output
Technical Specification
Specifications:
Input voltage: 12 to 16Vdc, 11.5A max.
Output voltage: Variable, see table below
Output current: Variable, see table below
Output plugs: A choice of 8 power tips are provided, please see table below
Output power: 120W max.
Dimensions
(main adaptor unit): 110mm (L) x 60mm (W) x 35mm (H)
Output voltage Output current
DC15V 6A
DC16V 6A
DC18V 6A
DC19V 6A
DC20V 6A
DC22V 5A
DC24V 5A
taken from your link
:blush: :blush: :blush: ok
gezt:
:oops: :blush: :blush: ok
Still a good buy though, I have been using one of those for about two years now, it is on about 12 hours a day 6 days a week and is still working as it did when new
