robroy:
You say you have a bad back?.. you had a lucky escape if they were using tilts.
Full strip outs …[zb] horrible things.
I even preferred putting 3 sheets on a flat, much easier.
Did not do many strip outs on Ewals, but Portbridge and Schenker it was regular.0
I was using a tilt on local/medium distance UK work alternating between using it as a tilt and a flat sometimes many times a week sometimes even in the same day.I was generally using the tilt cover as a sheet when using it as a flat.
I don’t get all the exaggerated bs about how supposedly difficult working with tilts is/was.
It doesn’t even get close to handballing trailer loads of often heavy boxes front to back floor to ceiling in a box trailer twice every shift in a UPS type hub system operation.
I also don’t get how you could possibly think that sheeting a flat was easier than using a tilt.Which in my experience was not much if any different to using a curtain sider bearing in mind it only needs to be stripped to a flat for over head loading type jobs like paper reels and rebar etc.Although luckily in my case that was always done at the yard usually with some help but no big deal.
