There’s something thats being overlooked here.
This constant dumbing down has unpleasant results, and we see those results every day of the week, idiotic accidents that should never happen, rollovers especially.
With a manual box (and preferably a vehicle without all this traction control garbage) the driver naturally knows and pre plans an approach to a situation re- speed and conditions, whether it be heavy traffic, roundabout, double bend, anything, if taught properly to use the lorry’s equipment, as in retarder, then the driver will know exactly what gear they are in and therefore the speed as they enter the hazard.
An auto takes away this driver involvement, i don’t hold with this salesman type ■■■■■■■■ that auto leaves the driver free to steer etc…what it does do is leave the driver in a semi comatose state of just sitting behind the wheel steering the bloody thing (with all that free time you’d think they could remember they have a 15’9" trailer on as the pass under the 14’3" bridge, never mind that accident won’t be on my licence eh! no worries), not worried about approaching road conditions or cambers or trival stuff like having a precise knowledge of approach speed to hazard, driver matching gear to road speed already knows their speed.
The truck will sort it out innit, too fast likely to lift the inside drive axle wheel and spin out? no worries the traction control whatever fancy name its been given at the time will control it, don’t need to plan anymore, and i don’t mean to imply that this planning is a constant hard thought process, good real lorry driver approach planning becomes normal to the good driver, as does seeing all things important as they appear.
Lorry driver will feel through seat of pants that traction is getting light at the wheels, steering wheel attendant won’t ever know it happened, the lorry sorted it out…except the SWA didn’t learn anything, didn’t feel the subtle shift happen, didn’t get that light feeling when the inside drive wheel starts to lose traction or that heart in mouth moment of tractor starting to go into an oversteer slide, lorry drivers have all been there its a fast learning curve, you learn to appreciate very quickly just how little traction there can be when conditions combine.
SWA learned not a thing about his vehicles load config, tyre grip on different surfaces, power application, or how the vehicle’s roll starts to build as all the above come into play, as none of the above were transmitted to him unless he noticed the little blinking light telling him the TC had done something, but seeing as modern lorries flash more bloody lights than you can shake a stick at it wouldn’t have registered anyway.
SWA also didn’t learn not to apply power or change gear at the wrong time on a bend, non Volvo autos often change mid roundabout, MAN’s in particular.
Good drivers can make good progress in autos and will take them in their stride and in most cases appreciate the rest, as most here seem to find i believe the Volvo is so far ahead of the other rubbish it could almost be from another era completely, always in the right gear and never revving its bollox off for no reason when others nearly always select wrong gear at junctions (helps that Volvos pull instantly well from really low revs which many don’t)…BUT…Volvo have done something clever too, the retarder being adjustable and requiring a press backward to invoke full early downshift engine braking has kept some driver involment, driver has to remember to invoke it.
We all know that autos are here to stay, thats fine so long as we accept that more and more intrusive electronics will have to accompany them, there are far too many irresponsible overfast cornering rollovers now, things like GPS monitored cornering control will inevitably follow.
