2nd atempt
3rd go after resizing .
Paul Who:
Is it other post that has put the pic to big or my photo?. If so what size do I use?. Paul.
You need to crop the image, in Photobucket click on “edit” just above the image.
Then crop the image so that you cut out the white part and leave the photo.
edit: Resizing the image won’t get rid of the white part around the photo, that’s in the image and needs to be cropped out ![]()
Paul Who:
Go back to the pic in photobucket and click EDIT - use drop-down resize and select MESSAGE BOARD - save as replacement of original - the one on trucknetuk will automatically resize
EDIT may mean a wait of a few seconds whilst the pic uploads
to CROP the image in PB - select CROP and click the mouse on one corner of the pic and drag to make a ‘box’ around the image - whats in the box wil be the image used - then resize it as above
This is what it will look like after cropping ![]()
Paul Who, if you read the 6th post from the top of this page, there’s an explanation of how to crop an image at Photobucket.
Good luck.
Thanks will do…
test 6
I haven’t a clue what I’ve been doing, but I think I have it.
Paul Who:
test 6I haven’t a clue what I’ve been doing, but I think I have it.
ainacs:
Several drivers have asked me how to post a pic so I thought I would put this on here for information.Firstly get your pics up onto photobucket ( I know that there are others)
Once you have done that if you view your album a load of pics appear like this
There are 4 oblong boxes under each pic use a left click of your mouse over the bottom box marked IMG Code, it will change colour and copied will appear in a little yellow box like this and the oblong box will turn blue.
It will remain blue like this
Then all you have to do is go to your message and where you want the pic to appear right click the mouse and this should appear
Go to paste and it will turn blue like this
Now just left click on that blue bar and a load of letters should appear with each end your pic should then have been posted once you submit he message.
Hope this helps
Regards Pat
[/quote]
