truckyboy:
I dont lie, i merely tell about stories i have heard, the drug situation that happened to me …did happen…and for your information Mr CB, maybe we call it gas because its easier, it could be another obnoxious substance, and because it sprays up the night heater vent when not on, we call it that, also it can be called Narcotic Gas, and i have shown places that sell it, so now say thats a figment of my imagination.
G.A.S. Plug ‘All in One’: No longer available in exactly this one-piece form but the same function is in our installable N50546 pictured right, use installed or portable on 12v or with 230v adapter, now cheaper too! G.A.S. Plug - Brilliant Product! Protect yourself against narcotic gas attacks and gas leaks and now you can use it as a door alarm too. If the burglar function is set the alarm will sound if a door is opened and the interior light circuit activated. In either case just plug the G.A.S.-plug into your vehicle’s 12V or 24V socket and be protected. Do Note that the lighter socket used must remain live with the ignition ‘off’ for the alarm to work. For complete peace of mind some will want to have one in the cab and one in the living area too. After a few minutes of self diagnosis G.A.S.-plug surveys its surroundings and runs a permanent built in test and temperature calibration. In case of a gas leak or a narcotic gas attack the integrated siren sounds immediately and the control light also flashes rapidly. G.A.S.-plug stickerThe built in test, the temperature compensation & permanent self-diagnosis ensure an efficient function even under extreme conditions. Testable with normal lighter gas for added confidence. Warning sticker included. No installation cost No adjusting LED status control Intelligent temperature compensation E1 type approval 90dB Alarm level at ~ 50ppm narcotic gas Draws ~70mA. German quality but for UK sockets too. B
so its my mate once told me so it must be true
Explain how they do this please truckyboy the air which is drawn into a night heater to be heated via the heat exchanger and recirculated into the cab is drawn from inside the cab not outside the air which is drawn from outside the cab goes directly into the combustion chamber of the heater and is mixed with fuel and burnt and exits through the heater exhaust pipe outside the cab, so explain how you can be gassed from drawing air into the heater and blowing it out the exhaust when the air doesn’t enter the cab
Why have you copied and pasted an advertisement from a caravan mag
if you use a cooker or a barbecue or heater which is faulty in any enclosed area then carbon monoxide can accumulate so a alarm is a precaution
however it does not mean that you will be gassed deliberately by a bunch of scalliwags possessing a gas unheard of by doctors and scientists
in my home I have carbon monoxide and smoke alarms but they have been installed in case of faulty appliances etc not because I think some itinerant scallywag who knows more than scientists, doctors, professors
and anaesthetists will come along and gas or burn me.
so why have you copied and pasted ad from a caravan mag, B and q sell em too
Your not listening, sometimes its called a gas when in fact it isnt, and doctors and police know of a substance which is also called a ■■■■ drug ( rohypnol i believe ) this can be obtained as a spray, so call it what you like, it knocks people out, it has done, in the past. Now to carry on, i was told that a spray/gas can be put inside a vehicle by the exhaust outlet on a night heater, providing its not being used, there are also other ways to get an obnoxious gas inside a vehicle as we all know, so just as i was told, was the same way you learned your information, and that was by someone who you thought was/is more knowledgeable, so who am i to reason why, which brings me to the posters before you who told of their stories of when they were either gassed or knocked out, and you are calling them liars as well, so do we believe them, or not, i do.
truckyboy:
Give him a break, he’s guessing, as he was unconscious at the time.
It puzzles me how all those who call it an urban myth never explain what probably happened.
Waking up in the morning to find out all you valuables have been lifted makes you wonder how long they spent rooting round, then you wonder how, without waking you.
It seems most assume that gas is mentioned as a way to excuse oversleeping or overspending in a bar or whatever, I was on my way to Bulgaria to start a new life there. I have no proof gas/liquid was used, I have proof I was robbed and spent 7 fekkin days on a german services because of it.
In hindsight, an audible alarm on the windows and doors would have made a difference.
truckyboy:
neither has anyone else. there have been many reports of these gassing incidents, but no one has any proof, no one has been fatally gassed, no one has ever been caught gassing anyone, no gas cylinders have ever been found containing this gas which mysteriously doesn’t exist, where do these scalliwags manufacture this gas where do they fill the high pressure cylinders required to transport gas why have they not been pulled for ADR whilst transporting this gas
its a myth, prove me wrong
truckyboy:
So youre suggesting that there is a new breed of stealth robber? or does everyone sleeping by the road fall into a coma for 8 hours or so?
what has sleeping by the road got to do with it?
people get burgled at home and they don’t hear anything either
And they don’t have night heaters so cant blame that for them being stupid and allowing it to happen r they could say I have been gassed through the central heating
green456:
I hope its you it happens to next, then you can tell us firsthand what happened.
green456:
how can it happen to me its never happened to any.one
if your saying it happened to you , then you will have police reports
regardless of which country you were in.
scan these documents and post them here then I will believe you
But you cannot scan these docs cos they don’t exist do they fella
its a myth
truckyboy:
It is not a myth, when i had my motorhome i used to buy a magazine of the same name, there were various stories in there and one was about a spate of robberies in southern france ( marseille ) of motorhome owners, there was also a detailed advertisement about Gas Detectors and where you can buy them and have them fitted, and no doubt you can search the internet for them, so the Myth many speak about really is not. One of the many ways our eastern european robbers use to rob, is to use a young female lure, once after gaining entry to your truck, will ask for a drink, maybe alcohol, or could be soft drink, and she will put a drug into the drink, rendering you at her mercy so to speak, and once asleep, takes anything of value. Many drivers fell fowl to this scam, and lost running money, phones etc etc.
I too fell unwittingly for this scam, because it was so cold ( minus 20 ) and my mate wanted a bunk up, i didnt partake in that nonsense, asked a girl and a boy if they wanted to wait in my truck in the warm whilst their friend did the business in the cab next door, so as a gesture, i offered them coffee, and had one myself, and woke up a few hours later minus a few quid, as did my friend, but i always hid the bulk of my money and only kept some in an old wallet for that days use, so didnt lose a great deal but my mate did, practically everything he owned, had more on show i suppose.
I have found that since the arrival of the east europeans, their scams have followed, and are being used around the country, along with the other thieving scumbags they make a great team.
theres a new verion of this happening at this very minute!!! when your parked up at a msa,then 2 young scantily clad eastern European ladies will come up and ask you to give them a lift to the next junction… whilst your driving then they will both climb into your bunk and start fondling and caressing each other till you come off the motorway and stop to let them out.,at this point,one of them will invite you into the bunk whilst the other one will rifle your pockets,and cab for any valuables,then they both vanish sharpish once you’ve crawled off the one in the bunk,…I was personally robbed by this devious method on Monday,tuesday,twice on wedensday,and also on Friday…so be warned,and always carry cash!!!.. and as far as the gassing goes…don’t they just bung a c.o.2 fire extinguisher the wrong way into the cab so the gas comes in instead of the powder??..or would that be too easy?
some folk might think there victims when they’ve been gassed,but if I hadn’t been gassed back in 1987 then id have made it onto the old herald,makes me shiver just thinking about it…I know I must have been gassed,cos id only had 14 pints in a baghouse in Rotterdam before they flung me out ,so I went for a quick 45 as I only had time to make the ferryy flat out,and when I nodded off I woke up 29 hours later with a splitting headache and my clackerbags all red and swollen,so I definitely must have been gassed,otherwise id have been on the boat in time for it to sink…counting my lucky stars or what!!!,
dieseldog999:
dieseldog999:
If only you had a story about the Embassy Balcony you could tell.
dieseldog999:
dont be asking me to elabourate on that one…official secret act and all that…i wasn’t the one that fell off the back of the roof and caught his goolies dangling on a rope while the troops went in the front window…( or was I)■■?
I never used the services of the Eastern European ladies of the day plying their trade at La Jonquera at the border.
I would think while one or two are in the cab,you never know who is going to fiddle with your back door and mess up your load.
