I’ve been pondering a solution to this for some time. Well, not exactly a ‘solution’ because you can never prevent fuel theft.
However, if you can make the event ‘riskier’ for the offender, then the frequency of the event may diminish.
What prompted my interest was when someone mentioned that it is now possible to get a semiconductor that will both store a value, and compare that value against an input, either as a voltage, or as a resistance.
For those that I have lost already. Let me explain.
A ‘semiconductor’ is simply part of an electrical circuit. In this case an ‘integrated circuit’ or, what is commonly referred to as a ‘chip’. They come in various configurations for various applications.
In any vehicle fuel tank is a variable resistor. Which comprises a float, attached to an arm, which essentially moves a contact along a coil of wire as the float rises or falls. This action varies the output voltage of ‘sender’ unit which then drives the fuel gauge which, in itself, is a variable resistor. I know it seems strange that an electrical current is being controlled within a fuel tank, particularly if it was a petrol tank, but the technology is well established and is decades old.
Therefore in any fuel tank is an electronic device capable of providing an ‘output’. The application of such a Comparator semiconductor would be to ‘sample’ the input when the system is ‘armed’, and then compare the value throughout the period until it is disarmed. If the value changed by, for example more than 5%, allowing for vehicle movement due to weather or passing traffic, then the system would trigger an ‘output’.
What one then did with that ‘output’ would be a decision for the operator. It could trigger an auto dialler to a phone. In a ‘yard’ situation, it could dial a number that caused floodlighting and cameras to be activated. The signal could be used to activate the vehicle’s lights and horns.
The outcome is not problematic. It is the generation of that signal where the problem lies, particularly as manufacturers are not normally comfortable with significant wiring alterations.
It wouldn’t prevent fuel theft. But it would make it a far less palatable venture.
And if anybody brings it to market.
It was my idea. I thought of it first.
