newmercman:
The ministry have always had a hard on about ABS warning lamps in my experience, from the time they started fitting those green lights at the front of the trailers it seemed to be the first thing they checked. I drummed it into my drivers to keep on top of them to avoid unnecessary aggro. Performance wise, if you failed a test then you could expect a lot of drama. I’ve mentioned before about the trouble I had getting my 143 through the test because of the parking brake only acting on the drive axle and the design weight of 52tons. Achieving the required12% was impossible, I tried everything, new brake chambers, load sensing valves, a reline a couple of weeks before test, new drums and a reline, nothing worked, I ended up having a sit down with the TC and showed him everything I had done to try and hit the required braking force and showed him that the results I did achieve were far beyond what was required if the lorry had a GTW of 44, or even better the 40 tons it was plated at and I got in touch with Scania GB and they recommended reducing the size of the bolts in the 5th wheel mounting flitches to get the GTW down to 40 tons. What a [zb]ing joke!It would be interesting to know when this lorry was last tested and what results it achieved on the rollers, although with 6 knackered slack adjusters it would hardly have the same braking efficiency now. I would like to see what a lorry with similarly out of adjustment brakes would achieve on the rollers too, that would give a clear indication of the braking performance of the lorry involved in the crash.
Sent from my SM-T805W using Tapatalk
Parking brakes on units can still be a problem. In my opinion the efficiency could certainly be dropped on makes that pressurise the yellow line to the trailer. It’s not load sensing/air pressure issues it’s all down to the strength of the springs in the drive axle chambers and generally a new chamber will get most trucks through. However, as drive axle chambers are pretty pricey , like your reline, putting new pads in is a common trick to get a truck through. Another trick is putting the brake pedal to the floor before applying the park brake on the rollers. I’m not aware they get their knickers in a twist about parking brake fails these days.
The truck involved passed it’s MOT nine months earlier at 54% efficiency which may not sound great but I would doubt, with drums all round, it would have been jaw droppingly better than that new. The slack adjusters weren’t knackered, in a way that would impair braking in a catastrophic failure sense, provided they were adjusted ok. The lorry foundation brakes were reconstructed and tested by VOSA and they are saying a 34% but there’s a lot of ifs in that reconstruction. Despite the prosecution rhetoric it really doesn’t sound like the brakes were instant death trap out of adjustment. If the cams had flipped or a brake chamber push rod was reaching it’s end of travel it would be a different kettle of fish.
Considering, I would guess, an aftermarket slack adjuster would be £50 ish the ones with broken anchor brackets ought to have been replaced but I’m, as yet, unconvinced that would have stopped this. The 18 tonner I used to drive down that hill in didn’t have fantastic brakes and an extra ton of load per axle over a 32 tonner.
