newmercman:
Other than measuring brake stroke and lining/drum thickness, there isn’t much you can do to determine if brakes are going to be effective and I imagine that’s the case here.Air pressure loss will have the spring brakes kicking in, but that will have little effect on out of adjustment brakes as the spring application mirrors that of the pedal being pushed into the carpet.
So I assume that the investigation found that the brakes were out of adjustment, not through fade, but through inadequate preventative maintenance and the key word there is preventative.
As a side note to that.check out the details of the speeds here.
bathchronicle.co.uk/fatal-ti … OOPljel.99
As it stands they are saying a loaded 8 wheeler with just a few working brakes was being driven around on the limiter on A roads at up to 56 mph.Then slowed from 43 mph in one hit ( block change
) down to 4 mph without over shooting it’s turn,then ran it up to 26 at the start of the hill then back down to 20 mph then it started running away.What is noticeable is that his guvnor seems to have been slowing down for the junction before turning onto the hill using sequential downshifts to create required engine braking at least.
An answer as to the exact condition of all the respective brake linings and drums including evidence of over heating and diameters and lining thickness might help in answering at least some of the questions and whether that matches the picture painted by the prosecution.
Bearing in mind the implications if ABS could be shown as being capable of randomly failing and not failing safe in view of the FTA’s and DVSA actions regarding ABS warnings.Or for that matter a training regime based on gears to go brakes to slow. ![]()
