20 Until you had several calls saying “where are you, you should be there one hour ago, the good driver is able to do that run in 2 hours!”
21…
21…
22)…
22 reversed on to a slopind down bay and have not raised your trailer resulting in gettin your mudguard stuck under the wheel and ripping it clean off
23… ![]()
You’ve done Middle East work for the Turkish firm Uzun Arac
24 had early morning tip under the trailer.
25…
25: been over shap in a force 10 blizzard
26:
26… been woken up by your traffic planner askin ‘are you ok to drive…? you we’re just a bit smashed when I saw you last nite at the yard…’
27…
Been in so many tight spots that you have to jack the wagon more than 90 degrees on itself so many times to get out rather than reverse 300+ yards, that eventually you pull a suzy out ![]()
Had a dump in the back of a tipper and then noticed a double decker bus full of passengers
28…
29…
Just missed the Herald
oops! somebody beat me to it! ![]()
ok 30) you’ve just been flashed by a blonde in a short skirt wearing no ■■■■■■■ driving a Porche!
31)
31)31) Reverse onto a brand new loading bay with a container not noticing that the nearside door has swung round and gone straight through a closed roller shutter door smashing it off its hinges and cracking the blockwork wall that holds it in place.
32)…
until you’ve had a week on this viewtopic.php?f=2&t=55004.
33: in the channel tunnel “disaster”
35)…
36)…
You’ve been on Sally Traffic’s report for causing major chaos after a breakdown
You tried to inflate a super single with one of those coin operated forecourt airlines.
You`ve gotten ■■■■■■ at the TNUK “Do” and run around the hotel naked…
