It seems like a lot of confusion is being read into “the regulations” that is not there.
For reasons of clarity and rationalisation, Regulation
(EEC) No 3820/85 should be repealed and replaced by
this Regulation, (EEC 561/2006)
4 (d) ‘break’ means any period during which a driver may not
carry out any driving or any other work and which is
used exclusively for recuperation;
4 (e) ‘other work’ means all activities which are defined as
working time in Article 3(a) of Directive 2002/15/EC
except ‘driving’, including any work for the same or
another employer, within or outside of the transport
sector;
- A driver shall record as other work any time spent as
described in Article 4(e) as well as any time spent driving a
vehicle used for commercial operations not falling within the
scope of this Regulation, and shall record any periods of
availability, as defined in Article 15(3)(c) of Regulation (EEC)
No 3821/85, since his last daily or weekly rest period.
And the drivers quote below rules out the need for any RTD rules to be followed as a 25 minute break on a ferry satisfies both the RTD and 561/2006 at the same time counting as 15minutes. The extra ten minutes doesn’t count for anything but does reduce your working time.
They have been a decent place for me to work but the only thing I hate is being told to take a split break when you have only done 2-3hrs work
The only decision to make is whether it is work risking a 36k job for taking 45m when a further 30m would have been sufficient and not even necessary.
The OP said he is aware of the differences between breaks, rest periods and periods of availability, but it seems “the regulations” are getting in the way of understanding which is which.
A break can be taken at any time provided that you are not driving, handballing, closing curtains or washing the lorry. Minimum 15 to count for the rules.You can sit in the cab, jog around it, read a map, answer the phone, read ■■■■ or even log onto trucknet or readers wives
a rest period can only be taken when you are free to do as you like and must be taken within each period of 24 hours after the end of the previous daily rest period or weekly rest period.You do not need to know how long, you do not need to sleep in a hotel, or even in a bunk or couchette. All it says is that you need suitable sleeping facilities and the lorry must be stationary
For a period of availability you need to know how long you will be waiting, either by being told or by previous experience, even the bloke on the opposite shift can say, zb me I was there last week and it took them 6 hours to tip 4 pallets. You can sit in your cab, go in the canteen, jog around your lorry, answer the telephone, watch TV in the canteen or do any of the things you would do on break. If you are double manning you can count riding shotgun as POA.
Neil has often mentioned in the past that if the period fulfils the criteria for POA it will undoubtedly count as break.
