if you can make it there,then your fit to travel,if you can walk unaided,your fit to work,if you can speak to the " medical professional" ( they wont tell you what qualifications these people have though there definately not doctors,but will be some kind of social worker,physiotherapist etc.) then you can communicate,and fit for work,if you can ask the doorman where the office is,same again,if you can sit for 10 mins without pain or moving ,then your fit.if you can lift a kettle and make a cup of tea…same story.if you go alone…same story.it wont matter if your doctor has signed you on the sick for weeks or years,if the fanny decides your fit,then your binned from esa and then the fun starts when you appeal.you can sign on the sick for 13 weeks on jobseekers then they refuse to pay you,you can apply for esa,same dosh,after 6 months,they want you to go for the examination,you can cancel this several times as unfit to travel,then theres a bottom line,appear,or get dealt with in your absence,you will then get binned from esa,then you appeal and get kept on esa,then you go in front of a doc,and solicitor,again,you can cancel last min and drag it out,eventually you get told you have to see them or get binned from esa…if you go,or dont go,you get binned,then you go onto jobseekers whilst applying for esa again who will not take you on,unless you can prove your worse than when you were originally examined,at this point you go on the sick for 13 weeks to get your jobseeker dole dosh…during this period,you have to show evidence to esa that your worse,then you go back on esa,or its a good debate with jsa as to why you cant work,so you get binned from jsa,and esa at the same time,easy option is to just go through the motions of filling in the form every 2 weeks,it is to your advantage if you deny having a mobile phone,landline or internet as you are now too poor to afford one,you do not buy newspapers as you are too poor,you cant walk to the library,so any contact from them,has to be by mail,hence you will never find work from them anyway. i already tried by saying i was prepared to find work as a sheperds helper,or i would consider a job as an astronaut,but i wasnt prepared to travel…
