delboytwo:
Coffeeholic:
berewic:
Pre 07 rule changes you could work a 16hr shift if you had 4 hrs rest in not more than three breaks,Two, It was three in total, the last being at least 8 hours.
Hi Neil
with regard the 16 hour shift in the old regs would that actually be a 12 hour shift cos you are using the 4 hours as rest and not brake
and in the new regs if you take a 3 hour rest then a 9 hour rest tin the 24 hours the shift would be a 12 hour shift
To me, and I think to most drivers, a shift is the period from arriving at work (clocking on) until the moment I leave work (clock off) regardless of the various activities during that time. Some weeks I do 6 split daily rest periods, I have to as it is the only way I can legally do 3 Dublin runs in the week and each day I start at 05:00 and clock off at around 19:00. In those 14 hours there will be around 4 hours with the tacho on rest while I am on the ferry and that will go with the 10 hours I will take when I park up for the day to give me my daily rest period, but as far as I am concerned I have been at work from 05:00 - 19:00 and I will have done a shift of 14 hours and I will get paid for those 14 hours.
delboytwo:
for you day to be a 15 hour shift it would be 10 hours driving 1.5 hours brake and 3.5 hours other work
It could be any combination. It could be 1 hours driving, 13 hours other work and 1 hour break, it really doesn’t matter. You clock on, you clock off and the time in between is your shift in most people’s minds.
if you take a split rest is basically like going home and then coming back to work to start a new shift
delboytwo:
I.E 4.5 hours driving 45 Min’s brake 45 Min’s other work 3 hours rest start back 4.5 hours driving 45 min brake 45 Min’s then take 9 hours rest total shift 12 hours
To me, and most drivers that would be a 15 hour shift and that would be the amount of hours I would be booking on my time sheet.
delboytwo:
rest IMHO is not part of your shift in any way cos if it was we would all be doing a 24 hour shift. brake is, POA is, other work isrest is not part of any of your shift as it is rest
Well you are in the minority in the transport industry then Del, I don’t know any other driver who counts it that way.
Are you saying if you did my week where I do 3 Dublin runs you wouldn’t want paying for the 4 hours on the ferry on each of the 6 days because it’s rest? On second thoughts you better not answer that as the boss might be reading this and give you a job.
I’m booking and getting paid for those 24 hours even though it is part of my rest period.
This is really semantics, if you don’t like the term ‘shift’ swap it for ‘at work’, I don’t mind what you call it but I know when I am at work and want paying and when I am not. ![]()
Definition of the word shift.
A person’s scheduled period of work, esp. the portion of the day scheduled as a day’s work when a shop, service, office, or industry operates continuously during both the day and night
Tuesday I’m scheduled to go from Hatfield to Belfast and the portion of the day scheduled for me to complete that is from 03:00 until about 17:30. There will be about 4 hours when the mode switch will be on ‘bed’ during that time but as far as I am concerned I’m working a 14.5 hour shift on Tuesday.
When answering tacho questions on here I find it best to try to stick with the generally accepted and understood terms within the industry to try to minimise confusion. Most drivers understand, and use, the term shift to mean the period between starting work after a rest period and finishing for the day. Drivers often ask tacho questions on here and use the term spread over, there is no such term in the regulations but it is understood to mean the time between starting and finishing work and that word could equally be used in this case instead of shift.
