can someone tell me easiset way[equipment needed] to siphone fuel out of a trucks fuel tank,ta
also fines etc if you get caught ta
How bad are things getting at Stobbies!!!
Very simple way with a cloth and a pipe. Why do you want to know?
You must be able to afford fuel been on so much with stobart ![]()
2 questions about fuel theft?.. You havent bought a white Transit Pickup have you?
tooled-up.com/Product.asp?PI … er=froogle
Saves you getting a mouthful of fuel
Are you bored tonight
Wifey on the blob ![]()
Screwdriver and a rubber hose and a pump connected to the battery ought to do it
Or stick a jerry can behind your faring and fill that up before your tank but keep an eye out for the cameras as they will report you for theft.
Hope this helps
A good ■■■■ and spit should sort it
a pipe, a cloth, red line and a connector
if you can’t ■■■■ it then blow it dear…
Loadman:
said the actress…blah di blah di blah you know the rest
Well…get a plastic hosepipe long enough to be in the tank and to reach the vessel you are planning to transfer the fuel to.Then get your in the cab…blow all the dust away airline and put the nozzle in the tank…you then get a rag and attempt to seal of the tank which now has a plastic pipe in it and the nozzle of your airline while at the same time pressing the trigger to get the airline to work.As the tank pressurises the fuel will flow out.Now if at some time your fridge runs out of diesel you use the same system in the fridge fuel tank having undone the bleed valve or even the pipe going to an injector when the fuel starts to flow out of what you have done do it up again…yes this is a two man job… fire up the fridge.Or stick the pipe in the tank and ■■■■ like hell it’ll flow …eventually…great taste derv…lasts for hours.
Armagedon:
Well…get a plastic hosepipe long enough to be in the tank and to reach the vessel you are planning to transfer the fuel to.Then get your in the cab…blow all the dust away airline and put the nozzle in the tank…you then get a rag and attempt to seal of the tank which now has a plastic pipe in it and the nozzle of your airline while at the same time pressing the trigger to get the airline to work.As the tank vacums the fuel will flow out.Now if at some time your fridge runs out of diesel you use the same system in the fridge fuel tank having undone the bleed valve or even the pipe going to an injector when the fuel starts to flow out of what you have done do it up again…yes this is a two man job… fire up the fridge.Or stick the pipe in the tank and ■■■■ like hell it’ll flow …eventually…great taste derv…lasts for hours.
What I said, but you are raising the air pressure not creating a vacuum.
I have seen 1000’s of litres running down drains when someone was a little ambitious ![]()
I don’t want to be rude, but, how thick do you have to be to ask that question on here when you tell people who you work for & where you work! Even if your not nicking it from Stobart’s, someone will now think you are, the next thing you know your’e in front of the magistrates getting done for theft from employer! No reference for your next job and can’t go for a job thats needs a CRB check! Its not worth it.
Wheelnut…well done…10 points…silly me vacum indeed…air pressure is correct…must be old age…dementia.
Fileep:
2 sides to every story, maybe he’s selling a car and wants to rid of excess fuel? i know thats what i done when i had 3/4s of a tank in my last car ![]()
Ok I told him how to syphon fuel so I could end up as an accessary…someone who assists a perpetrator of a crime.
Drill and a bucket you know the rest…
I think he’s suffering from fuel poverty as a recent post was enquiring about driving off from a fuel station without paying.
ady1:
Just ask any ■■■■■ ![]()
