Ok it’s been a while since I have drove an artic .There is a couple of things I forget .I remember there is a button in the cab you press when driving with a heavy load .What is this called also one to help brake as well ?
The button you’re probably on about could be to lower the mid lift axle on the unit usually marked with 2 wheels and an arrow but does vary. The brake button you’re probably on about is now a lever usually to the right of the steering wheel but that could vary its called the engine brake and could have several settings.
HTH.
wind up.
FarnboroughBoy11:
wind up.
+1
FarnboroughBoy11:
wind up.
I’m bored waiting to pick up 24 pallets of juice so i thought i’ll give him the benefit of the doubt.
truck11:
Your foot
bald bloke:
FarnboroughBoy11:
wind up.I’m bored waiting to pick up 24 pallets of juice so i thought i’ll give him the benefit of the doubt.
2 spaces left drive, just pop over to Milton Keynes and pick 2 pallets of bog roll up… you got to go that way to come back ![]()
FarnboroughBoy11:
bald bloke:
FarnboroughBoy11:
That’ll be overweight this juice is heavy gear.
bald bloke:
The button you’re probably on about could be to lower the mid lift axle on the unit usually marked with 2 wheels and an arrow but does vary. The brake button you’re probably on about is now a lever usually to the right of the steering wheel but that could vary its called the engine brake and could have several settings.HTH.
Can you remember what it’s called ? When fully loaded or heavy load you press it and a we yellow light comes on ? Anybody ?
EastAnglianTrucker:
FarnboroughBoy11:
wind up.+1
+2
Full load a problem? getting Kays catalogue out used to work years ago… ![]()
can someone help me find the go faster button ,i know it’s here somewhere
Think the auxillary or service brake anybody know where these are ?
One I am looking for is the one to help slow down when braking ?
Other I think is when you have a load on to give more power ?
truck11:
check down the back of the bunk mate stuff always gets lost down there ,i lost an entire axle there once only found it when i was rooting for a couple of quid for a Costa
martyh:
truck11:
Think the auxillary or service brake anybody know where these are ?check down the back of the bunk mate stuff always gets lost down there ,i lost an entire axle there once only found it when i was rooting for a couple of quid for a Costa
Haha seriously mate the next post down ?
The button to help slow down you only use when loaded incase of jackknife .
The other loaded as well .
truck11:
martyh:
truck11:
seriously dude just press the buttons and see what happens
truck11:
You mean the brake pedal and accelerator pedal ![]()
DAF95XF:
truck11:
Other I think is when you have a load on to give more power ?You mean the brake pedal and accelerator pedal
I’m sure when your fully loaded there is a button you press to help slow down and a we orange light comes on .
Think this could be the other one .
viewtopic.php?f=5&t=73862
