As long as the vehicle weights less then 3500kgs or falls into any of the ones categorised above then yes the 5th wheel does not factor into it. its like saying someone with a B licence can’t drive a car fitted with a towbar unless they get a B+E
Motor vehicles with a MAM not exceeding 3,500 kg having not more than 8 passenger seats with a trailer up to 750 kg (1,700 lb).
Combinations of vehicles in Category B and a trailer, where MAM of the combination does not exceed 3,500 kg (7,700 lb) and the MAM of the trailer does not exceed the unladen mass of the towing vehicle.
Example: A vehicle with an unladen weight of 1.25 tonnes and a MAM of 2 tonnes coupled with a trailer with a MAM of 1.25 tonnes could be driven by the holder of a category B entitlement, as the MAM of the combination does not exceed the unladen weight of the towing vehicle.
The tour busses that the bands use can be driven on a minibus licence because they have less the 16 seats, so if you are old enough you could drive them on a car licence…
we have lots of ivecos and volvo s weighted in at 7.5 with small fuel tanks and day cabs and i know they are borderline to be plated at that
Must have to take a lot off it i always imagined that crowd i work for knew someone that knew someone
Yeah, the 3.5t limit for a car licence is just that, a limit. Between 3500kg and 7.5t is C1 and I think 7.5t to 36t is C?? Either way it can’t bend,
Actually does anyone know the upper weight limit for a rigid? (normal rigid I mean, none of this special stuff like cranes etc)
Even if said tractor unit weighed less than 7.5t it still weighs over 3.5t so it’s deffo a C1 licence on weight but I doubt it’s marked as a C1 vehicle so on those grounds it’s a minimum of a C providing the fifth wheel is “incapacitated” or something like that.
There isn’t a upper limit C is any vehicle over 7.5t
berewic:
If it’s still plated at 44 ton, you can’t even drive it on a class 2 licence, let alone a car licence.
Even If its plated at 144t as long as its not pulling a trailer you can drive the unit on a cat c licence
as long as the unit doesn’t weigh more than 32t
Nope. Doesn’t matter the weight. It is the structure of the vehicle that counts. 150t cranes can be driven on a Cat C licence if they are of a rigid construction.
32t is the limit imposed for a 4 axle rigid vehicle of standard design.
