Can anybody remember years ago in the TRUCK magazine there was a article about a firm that were using DAF ballast tractors pulling two trailers. I think they were used close to a dock area but were used on public roads. From what I can remember it was classed and taxed as a locomotive and speed limited to 20mph.
Big Bear:
There were several of these running around Teesport and Denby ran one to deliver trailers to the ports. In Teesport there was a specialist police unit set up to administer them. I remember the locos operated by Les Harriman. Bulkhaul and TDG as well as a few others.
They were a ballasted tractor unit pulling a converter dolly with a semi trailer hung on the back. It was done as a stop gap to take heavy tanks and containers to the ports when the 44 tonne intermodal rules only allowed for 6 axle trucks to run to a railhead…
I worked for a German company at the time and we ran 6 wheel MAN 410 Roadhaus. We were also Channel Tunnel trained and were able to self certify & seal loads bound for Europe without waiting for the British Rail inspector gadgie.
How silly was it that I could load 26 tonnes in Seal Sands and deliver it direct to Trafford Park or Willesden, but could not drop it in Hull or Teesport?
Big Bear:
Thanks for the feed back Did they pull two trailers
Well sort of, the locomotives pulled a short trailer with a ringfeder type coupling, this convertor trailer (dolly is fitted with a fifth wheel with a standard artic coupled to that.
But the showmans trailers definately do pull 2 trailers. You will often see an artic with a living van hung behind.
Thanks to Diesel Dave. I learnt something about ADR today.
Going back to my post about the locomotives around the dock area. I learnt that they are prohibited from carrying dangerous goods while pulling 2 trailers.
This would have put the kybosh on ■■■■ Denby and Stan Robinson with the LHV they developed. It could never have been used on ADR work
Driveroneuk:
I wonder if Ruth Kelly actually went for a ride in one to see for her self how well they follow before giving them the big no no?
i think youve answered your own question tbh.
i dont even think shes ever been in a lorry let alone one that good drivers owuld be able to drive and make it look like a doddle.
Gogzy mate, where did you see this? I saw onr today at the Newbridge roundabout…did so many ‘double-takes’ that I just about wrote off my motor . Very impressive though Ive gotta say!
i saw them heading towards dunfermline on the m90. though this was late at night so all i saw was the flashing beacon on the roofs. then the trailers as it passed.
I used to drive one of these contraptions for Les Harriman, then for TDG, from ICI Wilton to Tees dock around 8 times a day. It drove great in a straight line forwards, reversing it took about a day to learn. If you were used to driving artics, then you had to switch your brain around and steer looking at the dolly under the trailer
