Remy,
you don’t have to ■■■■ the connecting up to trigger the jaws locking with the king pin sitting on, not in, the jaws.
Following a trailer dropping incident where i worked many years ago, at the time we all thought and said it couldn’t happen, little did we know, a few weeks or months later i proved it could myself, so much for what we thought.
Had to pick up a loaded trailer which had been dropped on uneven ground facing down a slight hill to boot, the odd angles probably contributed to the problem.
Anyway backed under and the jaws locked home, but something about the sound wasn’t right, that satisfying kerlunk wasn’t as satisfying as usual, so i picked it and dragged it gently down onto level ground and went to have a poke nose, sure enough a gap between fifth wheel and rubbing plate and yep shine torch up its bum to find the king pin sitting comfortably on top of the jaws which were fully closed so dog clip could have and did indeed go in.
I think i realised the pin wasn’t engaged when first picked it up, but at the angle it was sitting at i could have picked it up again and again till i was blue in the face and it would still not have been right, so better to just drag it down gently to where i could sort it out proper.
So take a warning youngsters, the dog clip in means bugger all despite it being an all important box to tick on the corporate check sheet of pure ■■■■■■■■, all it does is makes it more difficult for a vandal to pull the pin for you or for something to get caught on a sharp turn and somehow extract the pin as you straighten back up again…which might sound far fetched but where my relative works, not a Brit company, they now have ungreased teflon coated fifth wheels with no traditional safety locking system (buggered if know why either
) which successfully allowed a couple of unplanned trailer drops due to the trailer itself grabbing the pin and unhitching mid-tight-turn
…needless to say that is now sorted.
Since then whenever i pick a trailer up i just shine me torch up its bum to see the jaws have the pin securely, takes 2 seconds and can save you a world of grief even if just once in your driving lives.
That dropped trailer incident, the lorry had travelled empty from Bristol, same as the other 364 evenings and it came off on The Embankment just along from the house of ill repute when the lorry found a bump in the road hard enough to bounce the trailer out.
On this subject it might be interesting if we all asked our trainers/assessors where we work if they’ve come across this or advise drivers accordingly…if they don’t and you have a trailer dropping incident and the circs are right you might just have a get out of jail card there.
