DonutUK:
Couple of questions…
What’s a “VBS”?
Also, how does the whole adjusting the skeletal trailer thing work? Is it done by hand, by air, ■■?
a VBS is a Vehicle Booking System number, this is used by at least three of the main ports, Southampton, Tilbury (39 Berth only) and Felixstowe (Trinity terminal), the first two ports, your time will be e.g. 14:00 to 15:00, this is the time that your details must be entered into the system, then after your details have been entered, you have 30 minutes to enter your registration number into the first computer at the port
At Felixstowe, if you have a 14:00 to 15:00 VBS time, you just queue up in the same way as normal, but you can arrive between 13:30 and 15:30, so, you actually get 2 hours
the VBS number will be provided by your allocated planner
the sliding skeletal is easy enough once you get used to it, some have a button (same type as a park brake button), pust the button, it apllies the brakes and pulls in the locking pins, move the trailer to the required position with the unit, then pull the button back out, the brakes will not release until the pins are back out again, if the trailer does not have a button, the red air line needs to be transferred to another male fitting on the front of the trailer, this will do the same as the button.
on SDC trailers, you will need to apply the park brake, as pushing the button does not apply the trailer brakes
