AndyM:
Wayne…This is how my instrustor told me how to do it for the first time… Dunno if it will help… but here goes…
Right, to Start with, FORGET the trailer is even there!!!.. you can parallel park, so just as you start to move backwards, get the Right Hand lock As soon as you can… look out the side window, or in the mirror, and get your back drive wheels about 2 ft from the yellow line…Once they are 2 ft away from the line then get your unit straight by getting the steering wheel back in the middle, again, as soon as you can, Now you should be running parallel with the yellow line on your right hand side… as soon as its straight, try and look out the passenger door window at the Herring Bone markings in the middle of the Reversing pitch… count back about 10-12ft, as you should be able to see the markings and numbers throught the window. Once you count back, 10-12ft, look out the drivers window, and start getting your drive wheels next to the line, this is bringing your unit drive wheels back out away from the line and your unit back in line with your trailer… NOW is the time you should think about you trailer.… as all this movement with the unit, will make the trailer go where you want it to… this happens without you having to think about it…
Once your rear wheels of the unit come away from the yelow line, you now look in your mirrors to get the trailer in view on both sides in the same amount… By this time you are Past the ‘B’ cone that is the cone in the middle!!
Now this is where you have to get the feel of backing up, with only very small movements of the steering wheel…once your unit and trailer are straight, and your front wheels are straight, put your hands in the ‘Quarter to three’ position on the steering wheel,… now you only move the wheel at **Most One Quarter of a turn.**Now, try to get a little more trailer visible in the right hand mirror, but remember, you can look out your window!!.. this will mean that you are guiding the trailer to the right hand side, and you should looking at your trailers wheels and seeing the line they are taking… if you need more turn, turn the steering wheel One quarter turn to the left. if you have got to much, then its one turn to the right…
Think of it like this …Going forward, you turn right, to go right, left to go left… well, your going the opposite direction now, so you do the oppsite, right to go left, left to go right… Make sense■■?..![]()
This is how I managed to do it, and after reading it back… I am having my doubts… but hey, hope it helps a little…
Keep ya chin up mate, I know exactly how your feeling… Been there, Done that.!!
All the best buddy…
Flippen eck!!!
I have drove artics for a while & I didnt realise it was that hard!
My Advise is this, Calm down take a deap breath, get you head out the window and slowly make your move, keep watching remember do it slow, then you can correct a wrong steer keep your head out the window, look at the drive wheels so you know where you are pushing,give a bit take a bit back, nice and slow and nice and calm.
take a shunt if you need to but if you do, take a good shunt and get yourself straight.
A friend had the idea that longer it took him to do the reverse shorter the road test would be specialy on a Saturday
I am not sure if it is true or not but he passed because he TOOK HIS TIME REVERSING!!
You can do it …you dont need luck just calm nerves!
See you on the road in your new topliner soon ![]()
