Having C+E manual and then passing D incl PCV initial dcpc
You will get D+E manual
If you have LGV dcpc aquired rights then you will get a DQC dated mar/apr 2018 for PCV and 09/09/2014 LGV if not got all 35 periodic hours
Once all 35 periodic hours completed before 09/09/2014 will get a DQC expiry dated mar/apr 2023 for both LGV & PCV
Related to this topic, is this a mistake on the DVLA website?
If you hold B,C1 and D1 and take C+E you get B+E and C1+E but not D1+E, but if you hold the same categories and take C1+E you do get D1+E, it must be wrong because you can’t take C+E without C.
Rog, it’s time for a strongly worded letter to DVLA!!
It is not an error or an omission
Sub categories are not shown when the main category is
Yes although I had to send it back and get a manager to manually verify it. It took an extra 8 weeks as you end up at the bottom of a backlogged pile.
I would always advise you double check your categories upon return of your licence and take a photocopy of all sides of your licence before sending it away.
This is the same for the licence
Read it again Rog, the table says if you take a C+E test you don’t get D1+E, but if you take a C1+E test you do get D1+E, this surely can’t be right.
It also suggests you can take a C+E test when you have a C1, again you surely need to hold C before you take C+E.
Look at the 5th line, it says under ‘licence held’ B,C1,D1 then ‘test taken’ C+E ‘upgrading’ B+E and C1+E
Look at the 3rd line, it says under ‘licence held’ B,C1,D1 then ‘test taken’ C1+E 'upgrading B+E,and D1+E
1968kg:
It does read like that but the first box tells you that you need a full C to do the C+E. That site, although official, isn’t always clear.
