UKtramp:
I am getting the distinct impression that you guys are not taking my refrigeration classes here seriously. Now please ask me any of you’re burning refrigeration questions that have plagued you for years. I am here to help and will answer them honestly and put your mind at ease, you cannot find what I can tell you on Google, well without knowing what you are reading anyway, otherwise you will never learn. So fire away before I get bored and go. This you’re opportunity, don’t waste it!!!
Question 1. What Will Be The Relative Humidity At Saturation Point?
Question 2. Explain The Principle Of Refrigeration
Question 3. What Is Air Conditioners?
Question 4. What Is Wet Bulb Depression?
Question 5. Define Relative Humidity?
Question 6. What Is Refrigeration?
Question 7. Difference Between The Refrigeration And Heat Pump?
Question 8. What Is Sensible Heat Ratio (shr)?
Question 9. How Much Resistance Is Offered To Heat Flow By Dropwise Condensation?
Question 10. Why Rate Of Condensation Is Higher On A Polished Surface Compared To Rusty Surface?
Question 11. What Is Mechanical Refrigeration
Question 12. Classify The Different Refrigeration
Question 13. What Are The Basic Units Of Mechanical Refrigeration Systems?
Question 14. Which Unit Produces Cooling Effect In The Refrigeration System ?
Question 15. What Is The Unit Of Refrigeration?
Question 16. What Is One Tonne Of Refrigeration ?
Question 17. What Is The Capacity Of One Tonne Machine In Mks System?
Question 18. Define Co-efficient
Question 19. What Is Relative cop
