Terry T:
DoubleQ:
and you can change gear while your stationaryDrove I-Shift, Powershift and Opticruise. I think they all allow changing gear while stationary.
Not if its still changing down when you come to a halt.
( ie the box is still between gears, displaying 7 > 1 etc )
Not that I want to knock the Scanie ( cos it easyly the best BOX, cos it has a cluch )
But I did have to take two stabs at the climb out of “Mr Crappers’s” yard 39T MASS
( would have been 44T Mass, but the Compost I loaded was dry !!)
In auto, The gear box just couldnt react fast enought
then proceeded to sellect a gear that was far to low.
resort: Lost momentum, Drive axle lost traction (slip’ing & kicking up the dirt ).
Leaving feeling darn silly, less than 2 lenghts from reaching Terra-firma.
Not that the Tractor had a lack of horse’s, 480 was plently
The gear box programming just didnt understand the situation
The only option was to take a run, and gun it up there [locked] in 5th gear
If Id had a manual box:
I KNOW i could have Block-Changed, and made it 1st try.
Info Crapper’s Yard:
if you never been there its down a Rutted Dirt Track,
off the B4042 between Midgehill Copse & Callow Hill
when East bound on the M4, you can see it on the left about 2 miles before J16
The track is steepest at the road end, about 1 in 6
So, My VOTE is most deffinatly for a MANUAL BOX every time.
de 2xQ
PS: control while reversing onto most RCD bays is made easy, as its usually downhill
just get it lined up, let the rig roll, and control your speed using the brakes ![]()
