Advice please nightheater for a van
My sister has a VW van which she has converted to a camper van are there any van specific nightheaters on the market or will a standard lorry heater work despite the van being on 12 volts rather than 24 volts any help much appreciated thanks
mazzer:
I would imagine there are 12v night heaters available as most ambulances have them. Don’t know where you’ll get them though.
melloronlineshop.co.uk do them but the price is scary
damoq:
mazzer:
If what damoq says is right, have a look on the net, or even Autotrader mag vehicle dismantlers section, for car breakers with retired ambulances in their yards.
there are some on ebay-12v about £680+ not cheap but new
I’m on the search for one too, they come up on ebay as 12v eberspachers and webastos. Secondhand they can be pricey and a new buy with warantee is probably a better option. As said by others a lot of ambulances were fitted with them along with BT vans.
Personally i wouldn’t bother with a second hand ,if you can afford it buy a new 12v Webasto air top with silencer and put the derv pump in a box so the clicking can’t be heard.there are too many problems that are expensive with second hand if you don’t have a donar for parts.alot of electricity board vehicles and others have cheap made in china heaters that you cant get parts for.
How about getting a 24v night heater from a truck breakers and running it through a step-up converter?
I went through all the options when I fitted one in my Discovery.
New are so so expensive. I bought second hand, re-conditioned and serviced. Never had a problem in 3-4 years and its used a lot :slight_smile: Bought on ebay but DONT buy anything Turkish !
Paid about £350 for the heater plus exhaust, silencer and ducting. Eberpacher on diesal. I have been told dont bother with petrol or LPG. Add an additional tank for diesal if need be. My mate added a seperate tank to his disco 3 so it can be done and a neat job too.
Once it’s in you will always use it :smiley:
Might sound daft but have a look in camping shops. There are heaters available that run off the butane gas canisters. They are only small but for a van it should be perfect, unless you want it to run through the night whilst your asleep.
Got a eberspacher in my camper self build. Got a 12v one from eBay, took a gamble to be honest paid £110 for it as he wasn’t able to test it. Providing it has its wiring loom and you get the switch you want and I did that and beach tested it… Fired up with no problems.
But its a gamble though.
I fitted a 12v webasto airtop from ebay on my boat 3 years ago and it runs trouble free. The tick tick pumps are noisy but you do get used to it. I think the newer pumps are quieter as well. techwebasto.com/heater_main/ … 776891.pdf
Sorry to go off topic, but do night heaters need a periodical inspection for CO safety like a gas boiler in a rented flat?
No, Ched. But keep it under your hat, the government just haven’t caught on yet.
Find a mk2 diesel Ford Galaxy / Sharan/ Alhambra at a scrappers they have a Hydronic fitted as standard (change the glow plug), you’ll need the fuel metering pump and the coolant pump, plumb into the campers heater/a separate radiator (this is the preferred option done on canal boats etc), then wire in a 12v timer & thermostat. If you’re really clever you can indirectly heat a hot water store too. They don’t take too much out of the battery for an hours use but I guess they’ll be a leisure battery anyhow and use about 0.33 ltrs per hour of diesel.
MADBAZ:
^+1
Just put a glowplug in the wife’s VW Sharan’s Eberspacher Hydronic D5Z. To be honest, never knew it was there until we had a cooling problem going over the tops into Yorkshire. Research (it was the water pump) revealed the “auxiliary heater”!
PS It was an absolute ■■■■ to dismantle - all the screws (T10 heads as I recall) were seized. Mellors for parts - he’s a nice guy too.
propex is what i have fitted
bluebird-type2.co.uk/heat.htm
Harry Monk:
I had one in my van for a while, it worked well but using a step up converter means you are drawing double the ampage, mine ran ok but i do run 2 x 205 ah batteries!
I imagine that an uprated battery set would be pretty essential for running even a 12v night heater though?
If the OP did want to go down that route, KTS are breaking a 62-reg Renault Premium, it’s only three weeks old, I don’t know what they would want for the night heater but quite a bit less than a new one I’d say.
I got a 12 volt one from a chap breaking group 4 prison vans! i also got a waeco 12 volt compressor fridge from him!
